Go Back   Home > Forums > > >
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 13th January 2013, 06:17 PM   #1
kkcinc is offline kkcinc  United States
Default SSE power transformer question
When you have exactly 440 B+ with tube rectifier and a 370-0-370 transformer, what can you expect your B+ to be with 375-0-375 transformer and same tube rectifier? What about solid state which I haven't tried with the 370-0-370?
Old 13th January 2013, 06:50 PM   #2
DUG is offline DUG  Canada
440*375/370=445.9459
At most a 1.35% increase in voltage.
And at most a 1.35% increase in power dissipation. (tube = constant current load)
This also assumes that the different transformers have equivalent source resistance.
Solid state Will raise the B+.
Be careful you do not exceed the filter cap voltage rating or the current supply capability of the transformer. Tube rectifiers offer a free "soft start" function that SS diodes don't.
Doug We are all learning...we can all help
"You can't stop the signal, Mal. Everything goes somewhere..."
Old 15th January 2013, 12:36 PM   #3
Thank you. I don't have the new tranny yet so I couldn't put the meter on it. This will help with my estimations. Edcor is great, but slow.
SSE  power transformer questionHide this!Advertise here!
Newbie Question - Power Transformer vs Isolation Transformer SparkyPete Tubes / Valves 10 2nd November 2012 07:13 PM
SSE possible transformer problem. a95sonoma Tubelab 24 16th May 2012 04:31 AM
Suitable output transformer for SSE? Pilsern Tubelab 5 21st June 2011 05:44 AM
SSE bias question Pez Tubelab 10 16th December 2010 07:02 PM
Tubelab sse transformer wires newtube Tubelab 9 12th May 2009 02:29 PM
