log from just finished HTTrack session :
HTTrack3.46+htsswf+htsjava launched on Wed, 11 Sep 2013 19:52:31 at Tubelab | Dedicated to advancing the state of the art in affordable high end audio. +*.png +*.gif +*.jpg +*.css +*.js -ad.doubleclick.net/* -mime:application/foobar
(winhttrack -qwC2%Ps2u1%s%uN0%I0p3DaK0H0%kf2A25000%f#f -F "Mozilla/4.5 (compatible; HTTrack 3.0x; Windows 98)" -%F "<!-- Mirrored from %s%s by HTTrack Website Copier/3.x [XR&CO'2010], %s -->" -%l "en, en, *" Tubelab | Dedicated to advancing the state of the art in affordable high end audio. -O1 "D:\RAZNI SAJTOVI\TUBELAB SITE\Tubelab new" +*.png +*.gif +*.jpg +*.css +*.js -ad.doubleclick.net/* -mime:application/foobar )
Information, Warnings and Errors reported for this mirror:
note: the hts-log.txt file, and hts-cache folder, may contain sensitive information,
such as username/password authentication for websites mirrored in this project
do not share these files/folders if you want these information to remain private
19:52:32 Info: Note: due to tubelab.com remote robots.txt rules, links beginning with these path will be forbidden: /wordpress/wp-admin/, /wordpress/wp-includes/ (see in the options to disable this)
19:53:41 Error: "Not Found" (404) at link tubelab.com/comments/feed/ (from tubelab.com/)
20:42:15 Warning: File has moved from tubelab.com/pc-boards/ordering/ to Ordering | Tubelab
20:42:16 Warning: Link tubelab.com/wordpress/wp-login.php not scanned (follow robots meta tag)
20:42:21 Warning: File has moved from tubelab.com/amplifiers/simple-pp-board/ to Simple Push-Pull (SPP) Board | Tubelab
20:42:21 Warning: File has moved from tubelab.com/designs/tubelab-spp/manual/checkout/ to Checkout | Tubelab
20:42:23 Warning: File has moved from tubelab.com/designs/tubelab-spp/manual/applications/ to Tubes and Applications | Tubelab
20:42:23 Warning: File has moved from tubelab.com/designs/tubelab-spp/manual/safety/ to Safety | Tubelab
20:42:24 Error: "Not Found" (404) at link tubelab.com/designs/tubelab-spp/manual/meters/ (from tubelab.com/designs/tubelab-spp/manual/)
20:42:25 Error: "Not Found" (404) at link tubelab.com/designs/tubelab-spp/manual/grounding/ (from tubelab.com/designs/tubelab-spp/manual/)
20:42:25 Warning: File has moved from tubelab.com/designs/tubelab-spp/manual/parts-list/ to Parts List | Tubelab
20:42:28 Warning: File has moved from tubelab.com/designs/tubelab-sse/manual/applications/ to Tubes and Applications | Tubelab
20:42:28 Warning: File has moved from tubelab.com/designs/tubelab-sse/manual/safety/ to Safety | Tubelab
20:42:28 Error: "Not Found" (404) at link tubelab.com/designs/tubelab-sse/manual/meters/ (from tubelab.com/designs/tubelab-sse/manual/)
20:42:28 Error: "Not Found" (404) at link tubelab.com/designs/tubelab-sse/manual/grounding/ (from tubelab.com/designs/tubelab-sse/manual/)
20:42:28 Warning: File has moved from tubelab.com/designs/tubelab-sse/manual/parts-list/ to Parts List | Tubelab
20:42:28 Error: "Not Found" (404) at link tubelab.com/designs/tubelab-sse/manual/gettting-started/ (from tubelab.com/designs/tubelab-sse/manual/resistors/)
20:42:28 Error: "Not Found" (404) at link tubelab.com/designs/tubelab-sse/manual/mounting/ (from tubelab.com/designs/tubelab-sse/manual/sockets/)
20:42:28 Error: "Not Found" (404) at link tubelab.com/opts-explained (from tubelab.com/designs/tubelab-sse/applications/)
20:42:28 Warning: File has moved from tubelab.com/amplifier-designs/845-se/ to 845 SE | Tubelab
20:42:28 Error: "Not Found" (404) at link tubelab.com/designs/tubelab-se/manual/preparation/ (from tubelab.com/designs/tubelab-se/manual/getting-started/)
20:42:28 Error: "Not Found" (404) at link tubelab.com/designs/tubelab-se/manual/capacitors/nowhere (from tubelab.com/designs/tubelab-se/manual/capacitors/)
20:42:28 Warning: File has moved from tubelab.com/circuits/power-drive/ to Power Drive | Tubelab
20:42:28 Error: "Not Found" (404) at link tubelab.com/construction/industrial/nowhere (from tubelab.com/construction/industrial/)
20:42:32 Error: "Not Found" (404) at link tubelab.com/construction/customer-builds/www.burningamp.com (from tubelab.com/construction/customer-builds/)
20:42:32 Warning: File has moved from tubelab.com/circuits/power-drive/cookbook/ to Cookbook | Tubelab
20:42:32 Warning: File has moved from tubelab.com/tubelab-sse/applications/ to Tubes and Applications | Tubelab
20:42:32 Warning: File has moved from tubelab.com/amplifier-designs/tubelab-sse/parts-list/ to Parts List | Tubelab
20:42:32 Warning: File has moved from tubelab.com/amplifier-designs/tubelab-sse/applications/ to Tubes and Applications | Tubelab
20:43:50 Error: "Not Found" (404) at link tubelab.com/email+.png (from tubelab.com/about-us/what/)
20:43:56 Warning: File has moved from tubelab.com/?p=211 to Welcome to Tubelab | Tubelab
20:44:23 Warning: File has moved from tubelab.com/?p=1276 to Tubelab Website Reboot | Tubelab
20:44:25 Warning: File has moved from tubelab.com/?p=935 to Email questions about PC boards | Tubelab
20:44:29 Warning: File has moved from tubelab.com/?p=932 to Another Recession | Tubelab
20:44:37 Warning: File has moved from tubelab.com/?p=227 to Simple Push-Pull (SPP) Board | Tubelab
20:44:52 Warning: File has moved from tubelab.com/?p=220 to Tubelab SPP Boards | Tubelab
20:44:52 Warning: File has moved from tubelab.com/?p=219 to The Universal P-P Driver Board | Tubelab
20:44:52 Warning: File has moved from tubelab.com/?p=218 to Octal driver board | Tubelab
20:44:52 Warning: File has moved from tubelab.com/?p=217 to Spud SE | Tubelab
20:44:52 Warning: File has moved from tubelab.com/?p=216 to MiniTron | Tubelab
20:44:52 Warning: File has moved from tubelab.com/?p=215 to Tubelab SSE update | Tubelab
20:45:06 Error: "Not Found" (404) at link tubelab.com/email.png (from tubelab.com/pc-boards/thank-you/)
20:45:06 Warning: File has moved from tubelab.com/?p=186 to Tax time | Tubelab
20:45:06 Warning: File has moved from tubelab.com/?p=214 to Tubelab SE update | Tubelab
20:45:39 Warning: File has moved from tubelab.com/?p=187 to New computer | Tubelab
20:45:39 Warning: File has moved from tubelab.com/?p=192 to Email overload | Tubelab
20:45:42 Warning: File has moved from tubelab.com/?p=193 to From the Nats | Tubelab
20:45:42 Warning: File has moved from tubelab.com/?p=196 to Success! | Tubelab
20:45:42 Warning: File has moved from tubelab.com/?p=197 to 3rd time’s a charm? | Tubelab
20:45:42 Warning: File has moved from tubelab.com/?p=198 to New Tubelab SSE PCB | Tubelab
20:45:42 Warning: File has moved from tubelab.com/?p=200 to Upload issues | Tubelab
20:45:43 Warning: File has moved from tubelab.com/?p=202 to New site design | Tubelab
20:45:56 Warning: File has moved from tubelab.com/?p=188 to Thanksgiving | Tubelab
20:45:56 Warning: File has moved from tubelab.com/?p=189 to Retiring the old PC | Tubelab
20:45:57 Warning: File has moved from tubelab.com/?p=203 to On the road again | Tubelab
20:45:57 Warning: File has moved from tubelab.com/?p=208 to Visit from Gamma | Tubelab
20:45:57 Warning: File has moved from tubelab.com/?p=209 to Accidents | Tubelab
20:45:57 Warning: File has moved from tubelab.com/?p=185 to Hurricane Wilma | Tubelab
20:45:57 Warning: File has moved from tubelab.com/?p=182 to ISP has been down | Tubelab
20:45:58 Warning: File has moved from tubelab.com/?p=386 to Tubelab SSE Schematic | Tubelab
20:46:00 Warning: File has moved from tubelab.com/?p=360 to Tubelab SSE Manual | Tubelab
20:46:00 Warning: File has moved from tubelab.com/?p=195 to The Tubelab SSE | Tubelab
20:46:00 Warning: File has moved from tubelab.com/?p=199 to Tubelab SSE prototype | Tubelab
20:46:00 Warning: File has moved from tubelab.com/?p=194 to Tubelab SE updates | Tubelab
20:46:01 Warning: File has moved from tubelab.com/?p=204 to Website makeover | Tubelab
20:46:01 Warning: File has moved from tubelab.com/?p=205 to New hosting service | Tubelab
20:46:01 Warning: File has moved from tubelab.com/?p=184 to Common PC board questions | Tubelab
20:46:01 Warning: File has moved from tubelab.com/?p=183 to The 833A amp | Tubelab
20:46:01 Warning: File has moved from tubelab.com/?p=179 to Email Questions | Tubelab
20:46:01 Warning: File has moved from tubelab.com/?p=201 to New SE design | Tubelab
20:46:01 Warning: File has moved from tubelab.com/?p=206 to Data recovery | Tubelab
20:46:01 Warning: File has moved from tubelab.com/?p=207 to Hard drive destruction | Tubelab
20:46:01 Warning: File has moved from tubelab.com/?p=181 to My first grandchild | Tubelab
20:46:01 Warning: File has moved from tubelab.com/?p=180 to The amp sales are on hold | Tubelab
20:46:01 Warning: File has moved from tubelab.com/?p=210 to Wilma destruction | Tubelab
HTTrack Website Copier/3.46 mirror complete in 53 minutes 35 seconds : 1069 links scanned, 995 files written (77067506 bytes overall) [77672018 bytes received at 24159 bytes/sec], 1.1 requests per connection
(14 errors, 60 warnings, 1 messages)
- More Vendors...
- Tubelab
- TubeLab website
