Go Back   Home > Forums > > >
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 5th December 2012, 12:09 AM   #1
Anchan is offline Anchan  United States
Default Gain of SSE driver stage
Hello,
I have seen several sources on how to calculate the gain of a simple tube stage, but all of the equations involve a plate resistor as a variable.
In the case of a CCS loaded triode, such as in the SSE, how does one calculate gain?
If the math turns out to be overly complicated, perhaps someone can answer these questions from practical experience:
1) what is the gain of the 12at7 as configured in the SSE?
2) what would the gain be if I swapped in a 12bh7 instead?
3) if I did swap in a bh7, should I change the value of the cathode resistor or bypass cap? I might bump up the ccs to 15-20ma.
Thanks!
Old 6th December 2012, 08:31 PM   #2
cotdt is offline cotdt  United States
Send a message via AIM to cotdt
With CCS, gain is close to mu. With 12AT7 about 50-60x, and 12BH7 about 16x. Try bumping up the CCS to 15ma. If the gain is too high, you could also use negative feedback to reduce it.
Gain of SSE driver stageHide this!Advertise here!
SSE as Single Stage Power Amp Davec113 Tubelab 4 6th December 2012 08:36 PM
Hey George How About An SSE Phono Stage? kkcinc Tubelab 7 14th April 2012 10:01 PM
Transformer based voltage gain + unity gain stage? soundcheck Solid State 2 10th August 2010 02:44 PM
Heretical Unity Gain line stage PLUS a little gain ? yagas Tubes / Valves 7 24th January 2006 01:30 PM
How to calculate the gain of an input-driver stage? Antonio Tucci Tubes / Valves 0 8th October 2004 12:25 PM
