diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Tubelab (http://www.diyaudio.com/forums/tubelab/)
-   -   Question about diode for SSE D3 and D4 (http://www.diyaudio.com/forums/tubelab/224437-question-about-diode-sse-d3-d4.html)
spendorite 27th November 2012 01:40 PM
Just checking if this diode available at Parts Connexion could be used for the SSE D3 and D4, would it be better than either IN4007 or UF4007 .......
BY228TR, Vishay 3.0A, 1500V, Avalanche Rectifying Diode (Sinterglass / glass-passivated),
DUG 27th November 2012 04:32 PM
1N4007 is a 1A 1000PIV standard recovery diode.
3A 1500PIV is a higher rating.
What are the diodes in the "SSE D3 AND D4" being used for?
spendorite 27th November 2012 06:59 PM
Originally Posted by DUG (http://www.diyaudio.com/forums/showthread.php?p=3259271#post3259271)
They were recently added to the pcb for some start up protection for the 5AR4 tube due to the fact that today's less than robust new production 5AR4 tubes often fail under high voltage startup conditions.
Junior 29th November 2012 04:59 AM
i recently rebuilt by SSE and encounter issue like sparking of the rectifier.
all was solved with just a simple mod as seen here.
tube rectifier diode mod
spendorite 29th November 2012 11:10 AM
Originally Posted by Junior (http://www.diyaudio.com/forums/showthread.php?p=3262027#post3262027)
Yes, this is the purpose of D3 and D4 on the SSE pcb.
Copyright 1999-2017 diyAudio
