diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Tubelab (http://www.diyaudio.com/forums/tubelab/)
-   -   SSE capacitors C12 and C22 voltage rating (http://www.diyaudio.com/forums/tubelab/222119-sse-capacitors-c12-c22-voltage-rating.html)
spendorite 23rd October 2012 09:47 PM
In the SSE manual C12 and C22 1500uf in the parts checklist shows a voltage rating of 50V but the purchase parts list it is 63V. Which one is correct or can either be used ?
Tubelab_com 28th October 2012 04:57 AM
Either can be used in most applications. If you are going to run KT88's at 100+ mA the 63 volt cap is a safer choice since the caps might see over 45 volts with some tubes.
Resources saved on this page: MySQL 18.75%
