Cheaper OPTs and dual secondaries - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Tubelab
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 12th October 2012, 07:32 PM   #1
zman01 is offline zman01  Bangladesh
Default Cheaper OPTs and dual secondaries
I've been trying to locate some budget OPTs with dual secondaries for a friend's SSE build. The Edcor CXSE come with choice for only single secondary; out of luck with the entry level Transcendars too - no 8 and 4 Ohm secondaries before their 15 watt model.
Only Hammond has as such, but they are rated for 100 Hz - 15k Hz which is much lower than the Edcor's (40 Hz - 18 KHz).
The tubes for this project are EL34s. My friend would be swapping in and out speakers of different impedance ratings and would like to have an option of 4 & 8 Ohms.
I have also thought about a OPT with 6 Ohm secondaries as middle ground, but also read that the impedance that the tubes would see from connecting 4 or 8 Ohm speakers would not be necessarily be linear (depends on OPT design).
Would appreciate any suggestions in this regard.
Old 12th October 2012, 07:54 PM   #2
tomchr is offline tomchr  Canada
tomchr's Avatar
Jack Eliano of Electra-Print recommends using 6 ohm secondaries as a middle ground between 4 and 8 ohm. Of course, when you load a 6-ohm secondary with a 4-ohm speaker, the primary impedance will be 2/3 of the nominal primary impedance and vice versa for when loading with an 8-ohm driver. For many practical purposes, this doesn't make that much difference.
When I had E-P wind my transformers, I still went with dual secondaries, though. I have my eyes on some magnetostats that come close to 3 ohm...
Another option for you may be to look at replacement transformers for various amplifiers. Triode Electronics and AES have some.
~Tom
Modulus-86: 40W/8Ω @ 0.000061% THD. HP-1: 3W/20Ω, 450mW/300Ω @ 0.000032% THD. DG300B and Other Tube Circuits.
Neurochrome : : Audio - www.neurochrome.com - Engineering : : Done : : Right
Old 12th October 2012, 08:52 PM   #3
Tom,
Thanks a lot for the suggestions. I wanted to double check as I read in a forum that Edcor did not confirm proportionate change in primary (for that particular discussion IIRC it was an Edcor OPT with 10k primary, builder loaded the 8 Ohm secondary with a 4 Ohm speaker to get 5k primary); it was working pretty well for the builder though.
Regarding replacement transformers, lot of the more affordable stuff I see at AES and Triode are mainly for guitar amps? Sorry if that sounds stupid, but I am pretty much a noob here .
Most likely Edcor GXSE (not CXSE as I had incorrectly mentioned in my first post) with 6 Ohm secondaries it shall be.
OPTs With Multiple Secondaries FullRangeMan Tubes / Valves 6 13th October 2012 11:20 AM
Dual secondaries transformer. lanchile Solid State 9 18th January 2012 03:48 AM
Dual secondaries with one bridge kzeprf22 Power Supplies 48 19th October 2011 06:55 AM
One transformer with 4 secondaries or two transformers with dual secondaries Baka Chip Amps 5 28th November 2008 07:39 AM
Need help with dual secondaries in series glt Chip Amps 5 12th November 2007 07:41 AM
Copyright 1999-2017 diyAudio
