Go Back   Home > Forums > > >
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 24th September 2012, 12:22 AM   #1
Alan Hope is offline Alan Hope  Scotland
Alan Hope's Avatar
Default Does it matter if the tubes touch?
Loving my TSE, swapped out Sylvania 45s for TJ Meshplate 45s, and after a horrible and very depressing muddy 8 hours or so they opened out big-time and sound fantastic, extended bass and treble. Very very happy.
However, they are much larger than the Sylvanias and, when seated fully in the sockets, touch.
I can't really think why that should be a problem, and may even damp them slightly. If it is a problem, then I'm not sure what to do about it.
FLAC, Ethernet over Mains, SB3, GD Audio DAC 19. Tubelab SE with TJ Meshplate 45s. Fostex FE208ez in Kirishima Horns with Fountek NeoCD 2.0 Ribbon supertweeters (0.68uF & LPads).
Old 24th September 2012, 12:31 AM   #2
Richard Ellis is offline Richard Ellis  Argentina
Richard Ellis's Avatar
Location: Mar del Plata, a BIG seasonal getaway city, can see the Ocean from our residence.
The "rule of thumb" is one and a half envelope widths between tubes, of that which is two different sizes, 1 1/2 times diameter of the smallest. Touching the two?.......Heat transfer one to the other, uneven heating, hot spots, EM fields..... the list goes on why this is not a good idea at all.
__________________________________________________ _______Rick.......
Old 24th September 2012, 12:46 AM   #3
Alan Hope's Avatar
Thanks Richard. However in order to separate the tubes I will have to move them off the board. I read a thread somewhere here which suggested that that can cause problems.
Looks like I have no option though ...
Old 24th September 2012, 12:53 AM   #4
Talk to George about relocating the sockets........When one builds a chassis, make it bigger than you think it should be.....then make it bigger still.
__________________________________________________ _Rick.....
Old 24th September 2012, 06:34 AM   #5
Alan Hope's Avatar
My chassis is big ... I learned from my last amp (Decware kit) that plenty of space inside is good. I haven't yet drilled the aluminium top-plate so no physical problem relocating the tubes, just that I had mounted the pcb just below the top-plate so the tubes on the pcb would poke through the holes.
I'm happy to mount the tubes actually on the top-plate, that's physically better in some ways, just they can no longer be on the pcb so this will introduce short lengths of wire which may either pick up hum, or alter the electronics in some way - not sure how critical that part of the circuit is.
The amp hums very slightly on switch-on, but becomes pretty much silent when B+ kicks in and I would like it to stay that way.
Does it matter if the tubes touch?Hide this!Advertise here!
iPod Touch 8Gb avant Swap Meet 0 27th January 2012 09:12 PM
FS: OLED Displays / Capacitive Touch Screens / Multi-touch ICs & More promixe Swap Meet 1 11th May 2011 10:15 PM
Could a mod please get in touch? montesquieu61 Forum Problems 1 24th October 2010 06:13 AM
WTB: Very inexpensive preamplifier...tubes or SS, doesn't matter Glowbug Swap Meet 0 19th July 2009 07:14 PM
Installing tubes upside-down? Bad? Maybe it doesn't matter? jarthel Tubes / Valves 11 10th June 2006 01:13 AM
Copyright ©1999-2017 diyAudio
