Go Back   Home > Forums > Commercial Sector > Vendor Forums > Tubelab
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 18th September 2012, 12:49 PM   #1
Default RIAA correction circuit for Tubelab Simple SE
I plan to build a Simple SE and wonder if I can add a RIAA correction circuit on it.
I have a vintage SONY turntable and would like to connect it to the Simple SE.
I've been reading a lot of material here on the forum and I know that Simple SE has a good gain, then I think I will not need a complet Phono Preamp, just a RIAA correction circuit. Am I right?
There are some options on Ebay and I'm not sure if would work well. How about this?
Thank you all.
Sgrilli AD
Old 20th September 2012, 10:34 PM   #2
You need an actual RIAA pre-amp - the Simple SE is expecting a line-level signal (up to 2 volts I would guess); the turntable will supply much less than that.
Hey is for horses.
TUBELAB SIMPLE SE rwlightner Tubes / Valves 7 14th May 2011 07:33 PM
Simple PP vs. Tubelab SE yoaudio Tubelab 23 2nd January 2011 03:48 PM
Simple SE Tubelab.com Fenn Tubelab 36 14th October 2010 01:42 PM
Tubelab Simple SE v.2 nic6paul Tubes / Valves 3 1st November 2009 12:59 PM
Second Tubelab Simple SE board done budmaestro Tubes / Valves 0 24th July 2008 12:18 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
