Pre-Amp For my Tubelab Simple P-P - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Tubelab
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 9th August 2012, 03:02 AM   #1
Einric is offline Einric  United States
Einric's Avatar
Default Pre-Amp For my Tubelab Simple P-P
I currently have an Aikido All In One populated with matched 6CG7's, the real ones with the shield.
I have started ordering parts to begin the build of my TL Simple P-P.
Will my 6CG7 Aikido be ok for driving the Simple P-P?
Should I change the drive tubes to something with less gain?
I love how it sounds as is, but I will be integrating the Aikido into the same chassis as the P-P to be a nice big pile of tubes so I want it to be right.
Old 9th August 2012, 05:16 AM   #2
My thought is that a buffer with a gain of < one is all that you need. Any more gain will be burned off in the volume control and result in a reduced Signal to Noise ratio.
I use an Aikido Cathode Follower following the volume control.
DT
Old 9th August 2012, 05:26 AM   #3
Davec113's Avatar
If the simple PP has the same gain as the SSE you do not need a preamp with gain. I am running a 12BH7 driver in my SSE and it needs about 12 dB more gain and just built an Aikido with 6SN7 tubes, which are the octal equivalent of a 6CG7, so it has 20 dB gain... it is 6-9 dB too much, so not too bad... I plan on changing the driver stage (eliminating the electrolytic cathode bypass and maybe the CCS) which will lower amp gain a bit. So I agree a preamp with a zero gain buffer might be the best bet.
Old 9th August 2012, 11:45 AM   #4
Bootstrapped 6v6 is a good sounding one two. Zero Gain.
Living Life Doing the Waltz in 4/4 meter.
Old 9th August 2012, 11:59 AM   #5
cjkpkg is offline cjkpkg  United States
+1 on the 6V6...I had mine running on a breadboard and it sounded terrific with the SSE, although my chassis ended up being about 1/4" too short...ARGH!!!
So now I am back to the aikido 6CG7/5687...
Next project is to get a good regulated PSU for the 6V6 and a proper chassis and get that up and running, it was THAT good.
Old 9th August 2012, 01:15 PM   #6
Einric's Avatar
So the general consensus is that I need to reduce my gain level.
OK.....so what low gain twin triode should I use in the driver stage of my Aikido to drop some gain off.
I will be using the volume control I currently have on my Aikido.
Old 10th August 2012, 03:35 AM   #7
boywonder's Avatar
Does the Aikido build manual still have the tube table(s) in it? Peruse the table and pick some low gain combos. They will most likely require a few R changes and possibly tweaking your B+ from where you are now.
Old 10th August 2012, 12:38 PM   #8
Einric's Avatar
It does.....However they all seem to have input gain around 19db.
I am open to looking at 8 & 9 series twin triodes I just don't know whick ones sound nice.
My 6CG7's are really nice.
If I have too much gain would I be better off maybe switching to a 100k Pot from my 50K?
Then I just can't turn the knob up all the way?
Old 10th August 2012, 02:32 PM   #9
boywonder's Avatar
That doesn't help........the higher load from the larger R pot makes life a little easier for your source, but may increase noise and you are still wasting gain since the pot will be turned way down.
Ideally you want the pot wide open/fully clockwise at your loudest listening session, since technically it doesn't make much sense to amplify the signal all over the place only to crank back the volume knob. If you never turn it up more than 12 o'clock say, you have too much gain (which is very common).
That's why unity gain preamps (buffers) are fairly popular around here. They provide enough current to drive long cables, feed a bi-amp system, etc. but don't provide any gain. You can get no gain with a passive pre (just a vol control and input selector) and sometimes this works fine, but if it cannot provide sufficient current FR can suffer.
Keep in mind that the potentiometers only subtract, both the 50K and 100K are roughly zero ohms when turned fully clockwise.
Old 12th August 2012, 11:26 AM   #10
BillEpstein's Avatar
DT
Is this the kind of circuit you mention?
ACF-2 Octal Aikido Cathode Follower Kit
Headphone output for tubelab simple SE amp 2bz Tubelab 5 18th January 2011 03:18 AM
input transformer for Simple SE Tubelab amp Salsero Tubelab 7 10th October 2010 09:22 PM
SIMPLE Aleph Pre-amp, jleaman Pass Labs 23 19th November 2009 02:16 AM
Tubelab Simple SE & Edcor waam68 Tubelab 2 6th March 2008 12:15 PM
Needs simple RIAA pre-amp parmar664 Analogue Source 2 30th March 2007 10:29 PM
Copyright 1999-2017 diyAudio
