Go Back   Home > Forums > > >
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 18th August 2012, 04:06 PM   #11
zman01 is online now zman01  Bangladesh
SSE Capacitor Values C10 C12 C20 C22
$250+ for a cap! Not for me sir!
Old 18th August 2012, 07:37 PM   #12
Davec113 is offline Davec113  United States
Davec113's Avatar
They give breaks on quantities of 4+...
Old 31st August 2017, 05:08 AM   #13
pelayostyle is offline pelayostyle  United States
Sorry to resurrect an old thread but I found some 1000uf 63V Nichicon FG in my stash box that I can use for C12 and C22. From Georges response earlier I would assume that this would be OK to use? Would the same apply for C20 and C10? Just wanted to double check with you guys.
Old 31st August 2017, 06:06 AM   #14
pelayostyle,
C10 and C20 are for 6.3 volt capacitors, right? Does a 63V capacitor fit in that space?
Old 31st August 2017, 06:09 AM   #15
pelayostyle,
I have the 6.3V version in 1000uf too.
Old 31st August 2017, 06:43 AM   #16
If our understanding of post #2 of this thread is correct, then 1000uf should be usable.
Old 22nd September 2017, 01:53 PM   #17
Altecboy is offline Altecboy  United States
Default cathode bypass cap for 12at7
I notice here and elsewhere there is much conversation about the size, type and bypassing of the capacitor to use to bypass the cathode resistor of the output tube.
How about the input tube? It would seem to have a similar effect. Maybe more.
Anyone have any experience with this?
thanks.
Old 22nd September 2017, 08:28 PM   #18
Tubelab_com is offline Tubelab_com  United States
Tubelab_com's Avatar
The bypass cap on the input tube performs the same function as the cap on the output tube, but sees far less current, so it is not as critical. I would still use a good quality cap because it is in the signal path.
A 1000 uF cap is OK, as is a 4700 uF (tried it because I had some) but I wouldn't stray too far outside this range. Too small of a cap will affect bass response, and too big could cause a warm up bias shift especially with a big coupling cap......I had strange results with 10,000 uF in the input tube bypass, 2200 in the output tube bypass, and 1 uF coupling caps. I tried them because I had them, but got some weird woofer motion that took a second or two to settle out when cranking some bass heavy music.
Tubelab, it's 5 year mission. To explore strange new tubes, to seek out new circuits and topologies, to boldly go where no tube has gone before......
Old 24th September 2017, 10:36 AM   #19
thank you George
SSE Capacitor Values C10 C12 C20 C22Hide this!Advertise here!
Help With Capacitor Values David E H Parts 0 5th November 2008 09:34 PM
about capacitor values StefanPoPolsku Multi-Way 16 30th December 2007 01:54 AM
Aleph 2, capacitor C9 and C10 loovet Pass Labs 3 10th January 2003 01:03 PM
