| Tubelab Discussion and support of Tubelab products, prototypes and experiments |
Hi Guys,
Need your help to check if my Hammond Power Transformer 374BX used in Simple SE is still in good condition? Reason for asking is because my last power up I heard a loud hum after a month of "hibernation". Upon power off, the 374Bx is very hot. Afraid that it might be dead/fried I had performed continuity/resistance measurement via a multimeter and the result as shown below. How I wish I do have another power transformer for the same comparison but is the 374BX still good/fit for use? Appreciate any form of advice. TIA
#2 |
Why not just disconnect all of the secondaries from the board and carefully check the voltage of each secondary with the transformer powered up?
The voltages should be a bit high since the transformer is completely unloaded, but that should answer your question. The 5V rectifier and 6.3V heater windings can be difficult to measure since they are usually less than an ohm. For reference, I just measured a 273BX (350-0-350 @ 175ma) and the B+ secondaries are 77R across the ends, and about 39R from either end to the CT. The 5V and 6.3V measure about .4R end to end. Last edited by boywonder; 27th July 2012 at 10:01 PM. |
#3 | |
It is extremely rare for a transformer to die from sitting on the shelf. Electrolytic caps and rectifier tubes are far more likely to die from non use.
Too much power is almost enough! Turn it up till it explodes - then back up just a little. |
#4 |
Hi Guys,
Really appreciate all the inputs. Will measure the secondaries without load tonite. |
#5 |
Had been housing the current wooden case SSE to Hammond Alu case all this while.
Done with the secondary measurement (WITHOUT load) and reading as follows: Red-Red: 800V Red-Red/Yel: 400V Green-Green: 6.25V Yel-Yel: 5.24V ![]() However, upon connecting to the SSE's PCB (tried all combination of setting be it 4/8ohm spk out, Triode/UL or with or without CFB), the 374BX hum (vibrate) and can be heard and feel. By just removing the Red-Red & Red-Yel wires (#2 from pic attached - No Load on High Tension) from the SSE's PCB no hum (vibrate) of the 374BX can be heard (feel). Question: Without load no hum (vibrate) with the above measure on the secondaries. But with load 374BX hum (vibrate) upon power ON. Is the 374BX defective and what else can I do? Appreciate any kind of inputs and advices/suggestions. Thanks |
#6 |
To add on, the power ON was done without the tubes.
#7 |
Is it possible that I had fried the FRED Diode (D1 & D2) that resulted in the shorted Red-Red wire of the 374BX resulting in Hum (vibrate).
I measure the continuity of the diode and was found that the diode body (k-cathode) was shorted to the anode as beep beep sound was heard. (no tubes inserted into any of the tube sockets).
#8 |
Junior: What's your B+ voltage and heater voltages when all of the tubes are installed and a proper load is connected to the speaker terminals?
If any of your voltages are out of spec (low), that would indicate a short condition and would make the transformer hum. Are the screws clamping the end bells on the transformer tight? |
#9 | |
#10 |
hi boywonder,
checked all the screw on the power transformer is all secured tightly. i mounted it on top of an aluminium Hammond chasis. Hi Geroge, Desolder both D1 and D2 (both are ISL9R8120P2) and check via DMM. D2 is "dead". replace both D1 & D2 with DSEI12-12A. Hope I had nailed down to the culprit. Will try it out tonite and report back. |
| Diagnosis please | bullpeters | Tubes / Valves | 19 | 31st July 2012 06:47 PM |
| Bad Tube in my "new" Hammond C2 Organ preamp? HELP w/ diagnosis!! | jeffstev | Tubes / Valves | 10 | 24th November 2011 05:59 PM |
| Simple SE using pwr trans without ct | stoolpigeon | Tubelab | 1 | 24th May 2011 10:00 AM |
| driver diagnosis | agrobler | Multi-Way | 3 | 26th April 2006 12:58 PM |
| Diagnosis needed! | fender4 | Solid State | 14 | 3rd July 2002 09:18 AM |
