Go Back   Home > Forums > > >
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 24th July 2012, 06:58 AM   #1
neomat is offline neomat  France
neomat's Avatar
Smile Starting a SSE build
Hi !
Like I said in the thread "Board availability", I received my SSE PCB. It's from the new batch and I've some questions (I think George may/will be updating his website when less busy), so I made my thread...
a_ 2 diodes are added (D3 & D4) on PCB. Referring to SimpleSE: C1 value, it seem to be 1N4007 diodes, like these 1N4007-T Diodes Inc | 1N4007DICT-ND | DigiKey . Am I right ?
b_ A place marked TR1 is also added, which semms to be a GE CL140. I don't see other components that could have be discussed in a thread...
c_ Two unused holes are under C22. What is their function ?
For the moment, I do not have any other component, but here is my purchase list :
- big CXSE25-8-5K Edcor OPT
- Edcor XPWR059 (750V (375-0-375) @ 175mA CT, 50V @ 50mA, 6.3V (3.15-0-3.15) @ 6A CT and 5V (2.5-0-2.5) @ 3A)
- Edcor choke
- Standard purchase list from Tubelab website
- KT88 tubes
- maybe no SS rectifier
- A cathode bias resistor switch (rotary or toggle, don't know yet)
I will take my time (I'm pretty busy (work, familly, ...). moreover, Edcor order is about 400$ , I'll wait few months to save money...
It's gonna be a really nice project !
Old 24th July 2012, 03:47 PM   #2
Davec113 is offline Davec113  United States
Davec113's Avatar
Great, good luck!
If you want to save money, maybe try EL34 tubes first, they are a bit cheaper and I preferred them (-C- EL34) over some new issue Tung Sol 6550s. If you implement your cathode resistor switch you can always buy the KT88s later.
Old 24th July 2012, 11:01 PM   #3
Tubelab_com is offline Tubelab_com  United States
Tubelab_com's Avatar
There are 3 new components on the new board. If you really want your board to be exactly like the old board all 3 can simply be replaced by a jumber wire made from a resistor lead.
D3 and D4 are indeed 1N4007. I suppose a purist will use an UF4007 but it shouldn't make any difference since the rectifier tubes characteristics dominate.
TR1 is a GE CL140.
All 3 or these components were added to make life easier on the rectifier tube under start up conditions. Many of the current production tubes aren't built like the old ones were.
You may find that 47uF 500V electrolytics are hard to find. 56uF's seem to be available, yet this is above the reccomended limit for a 5AR4. I am testing the 56 uF with several dozen 5AR4's and the 3 added parts before recommending this though.
The 2 unused holes near C22 are for connecting the circuit from one side of the board to the other. No components are placed in those holes. These "extra" holes have been in all SSE boards made.
These boards use plated through holes. This means that there are copper circuit traces in ALL of the holes. Many of the holes used for component leads are also used for top to bottom connection. Do NOT drill the holes out to fit a fatter component lead.
There has been exactly ONE SSE that didn't work and couldn't be fixed on this forum. I had the builder send it to me and found that he had drilled the coupling cap holes larger to fit some really big caps with really fat wires. This killed the connection, and broke the amp. The cure is to solder the component to the board on both sides so that the component lead completes the connection.
Tubelab, it's 5 year mission. To explore strange new tubes, to seek out new circuits and topologies, to boldly go where no tube has gone before......
Old 25th July 2012, 06:42 AM   #4
neomat's Avatar
Thanks George for this detailed answer.
Thread about C1 value mentions 33F, which logically seems better for the tube.
Yep, I saw that in 1 or 2 threads, for example : R3 soldering pad ruined
Old 25th July 2012, 06:54 AM   #5
Davec113's Avatar
I would go with less than 47 uF for c1 unless you plan on buying a NOS 5AR4, the new ones will eventually arc over and fail. When I first built my SSE I also had a preamp with a 5AR4, and I had a Sovtek and a JJ go out on me. After purchasing a few NOS tubes I went the next 4-5 years with no problems. The diodes added probably save the new 5AR4s, as they can't seem to perform up to spec. You can get a 47 uF 500V JJ cap from partsconnexion.
Old 25th July 2012, 04:30 PM   #6
rknize is offline rknize  United States
rknize's Avatar
Send a message via AIM to rknize Send a message via Yahoo to rknize
33uF should work fine in that position and won't affect the B+ is any meaningful way.
Old 30th January 2013, 06:25 AM   #7
neomat's Avatar
Hi all !
I'm updating this post !
I'm starting soldering, even if I'm lacking R14/ R24 (10K 3W) and R2 (150K 3W), and the GE CL-140.
In BOM, these resistors are metal film oxyde, is it ok if I order carbon film resistors ?
I just have another question : what is the approximative length of Edcor transformers wires?
Thanks !
Old 30th January 2013, 09:40 AM   #8
rock12 is offline rock12  United States
these are not shown on the schematic? how can they be added to the old design?
Old 30th January 2013, 10:18 AM   #9
neomat's Avatar
You can find D3 and D4 in a post mentionned in my first post, and the CL-140 is added in main input, to be confirmed.
Old 30th January 2013, 02:46 PM   #10
rknize's Avatar
Hi all !
In BOM, these resistors are metal film oxyde, is it ok if I order carbon film resistors ?!
As long as they have the right power rating, they will work fine.
Starting a SSE buildHide this!Advertise here!
Starting a First Watt F3 build and need some help Marsfrogie Pass Labs 59 7th October 2010 12:13 AM
Starting a Simple SE build... oldmanStrat Tubelab 75 29th April 2009 02:05 PM
Starting my Bottlehead Paramour 2A3 build Wardsweb Tubes / Valves 2 19th August 2003 10:42 PM
