Go Back   Home > Forums > Commercial Sector > Vendor Forums > Tubelab
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 27th June 2012, 05:52 AM   #1
Davec113's Avatar
Default Bypassing Power Tube Cathode Caps On SSE
While I was putting together a list of parts to replace on my SSE after ~4-5 years of use I decided to order some extra film caps to bypass the power tube cathode caps. I chose the Vishay MKP1837 metalized polypropylene, .1 uF, 160V, $2.25/ea.
The result is a noticeable improvement. It sounds smoother and clearer, there is a harshness or graininess that disappeared allowing you to hear more detail in the music. It is moist noticeable in the high frequencies, there is a "sparkle" or "glare" that has been removed. It makes it sound less exciting on some tracks, but I am sure that what was eliminated was a distortion. It doesn't seem to have any affect on the overall character of the amp, tone and soundstage seem to be unaffected. I think it is a bit easier to listen to overall... I have Omega Super 5 XRS speakers, which are a 5" single drivers that can be very unforgiving if used with poor equipment, these speakers have no xovers and react strongly to changes.
I am thinking I will now have to do the same for the driver tube.
Hopefully within a few days I will get to the Hazen or CCE mod described in my other thread
Old 27th June 2012, 03:12 PM   #2
GanzerD is offline GanzerD  United States
Newbie here....
Am I correct that you are bypassing C12/C22? I am running it with CFB....Does this still apply?
TIA
Dave Ganzer
Old 27th June 2012, 05:22 PM   #3
Davec113's Avatar
Originally Posted by GanzerD View Post
Newbie here....
TIA
Dave Ganzer
Yes, it is C12/22. I don't think using CFB will matter.
Bypassing filter caps with Smaller caps mbeards Tubes / Valves 28 8th April 2012 10:47 PM
Variable cathode bias in SSE: 1k Ohm pot? Horsebox Tubelab 7 7th April 2011 10:19 PM
Bypassing cathode resistor on pp power tube betrest123 Tubes / Valves 5 17th August 2010 11:53 AM
bypass caps for bypassing mylar caps? crippledchicken Multi-Way 4 27th February 2008 04:24 AM
Bypassing bias stage with caps EchoWars Solid State 5 21st November 2003 08:16 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
