Simple P-P Resistors - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Tubelab
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 20th June 2012, 10:33 PM   #1
Einric is offline Einric  United States
Einric's Avatar
Default Simple P-P Resistors
I have quite a supply of NOS Motorola Carbon Composition resistors in my file.
I was wondering if I stick to at least the wattage rating of the required resistors and bin them them for tolerance would they be suitable for use?
I understand that CC resistors will drift with temperature but assuming decent air flow that shouldn't be an issue right?
Old 21st June 2012, 07:52 PM   #2
rknize is offline rknize  United States
rknize's Avatar
Send a message via AIM to rknize Send a message via Yahoo to rknize
Yes, they will work just fine. Just note that CC resistors tend to introduce more noise than other types.
Old 29th June 2012, 01:44 PM   #3
Einric's Avatar
Do the Carbon Film resistors bring in noise?
Are they a suitable replacement for the Metal Film?
Old 29th June 2012, 02:15 PM   #4
akimmet is offline akimmet  United States
If you need to buy new resistors, just buy the metal films. The difference in price on small quantities (under 500) is completely negligible. However; I wouldn't hesitate using carbon film if that was what I had on hand.
Carbon comp on the other hand are known to be very noisy. What is worse is over time they can drift in value by more than 50%.
Old 29th June 2012, 04:56 PM   #5
Davec113's Avatar
I would only use them for grid stoppers. PRP metal film are a good deal (kinda, relative to Vishay bulk foil at least) for an "audio grade" resistor with non-magnetic construction. Kiwame carbon film are warmer (and available as a non-audio resistor for 1/10th the price), and Amtrans just came out with resistors including a carbon film that's supposed to top the Rikens, which are now out of production. Riken and Amtrans should be less warm and more detailed vs Kiwame but are still carbon film.
I also just replaced Kiwame with Mills wirewound in the cathodes of my EL34s in my SSE and they are less warm and more neutral... probably the cleanest option I have heard so far, but depends on your personal preferences. I also use Mills resistors in the power supply.
Old 1st July 2012, 02:16 PM   #6
Einric's Avatar
Is the 5% tolerance good enough or should I be picky with the values to get as close as possible to nominal value?
A lot of the Metal Film are 2% which is nice but I have a bunch of 5% Carbon Film on hand.
Old 1st July 2012, 05:39 PM   #7
Even 10% tolerance won't hurt anything. Go right ahead if you have 5% carbon films.
Why do people say they can't hear resistors, or all resistors are the same? spice house Multi-Way 184 16th April 2012 12:58 AM
5 Watt Resistors on Aleph 4 and Holco Resistors nicharis Pass Labs 16 8th February 2012 07:50 AM
FS: Resistors, LM3886, speaker terminal, variable resistors, switches and rectifiers chris-man Swap Meet 1 28th May 2009 11:47 AM
Inductive resistors for source resistors bbakota2000 Pass Labs 12 25th March 2005 11:33 AM
Weird Resistors, anyone know anything about resistors priscared Parts 1 19th March 2004 11:59 AM
Copyright 1999-2017 diyAudio
