Simple SE GU-50 - Page 4 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Tubelab
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 2nd June 2012, 03:49 AM   #31
Einric is offline Einric  United States
Einric's Avatar
So with a 12AX7 in the driver position on my Aikido I should have right around 30V of gain.
Will this be sufficient to drive a SE GU50?
What would be the best way to implement the above circuit with a 12AX7-6CG7 Aikido as the driver?
Old 2nd June 2012, 04:25 AM   #32
Einric's Avatar
Or....Wave.....Do you have a circuit for your Gubernator that is complete and ready to build in GU50 Triode?
I can follow your schematics very well and all I will need to build is a pick list.
Old 2nd June 2012, 05:50 AM   #33
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
I think the version on my Forum that Knarf simulated is ready to breadboard.
Here it is:
http://wavebourn.com/forum/viewtopic.php?p=25154
The Devil is not so terrible as his math model is!
Old 2nd June 2012, 06:27 AM   #34
My variations on GU-50:
For my taste is the best sounding with 6J52P
Old 2nd June 2012, 01:18 PM   #35
Einric's Avatar
All of those options look great, they are also nice because my multimeter only goes up to 600V.
I will look through them an make a decision.
Would an Edcore GXSE10-6-10K suffice for these circuits?
This would help keep the iron cost down.
How well do the 3.5K OPT's work?
Old 2nd June 2012, 01:33 PM   #36
Einric's Avatar
Do the 6J52P valves us a standard 9-pin socket?
Old 2nd June 2012, 01:42 PM   #37
Einric's Avatar
Wave, do you (or anybody) have an English translation of the GU50 datasheet?
Old 2nd June 2012, 01:52 PM   #38
Einric's Avatar
Would a 6Ω secondary be OK for 4-8Ω speakers?
The speakers I will be building for this amp are 6Ω but for future purposes I'm just wondering.
Old 2nd June 2012, 02:52 PM   #39
Wavebourn's Avatar
No, English was language of "potential enemy".
Search for LS-50 datasheet, it is in German.
Old 2nd June 2012, 02:55 PM   #40
Wavebourn's Avatar
Use Google Translate - we discussed this matter in that topic. It is not about speaker, it is about optimum load of the tube. Search here on the forum for load lines. GXSE10-6-10K is what doctor prescribed for Frank's schematic. However, for better bass I would use 25W Edcor transformer instead of 10K one.
GU-50, GM70 and KT88 nina Tubes / Valves 55 19th February 2017 11:16 AM
GU 50 monoblock gedd Tubes / Valves 8 21st October 2011 10:08 AM
GU 50 output modification beamnet Tubes / Valves 22 15th January 2010 03:02 PM
Use of 12j1l and gu-50 tubes gemby Tubes / Valves 6 26th October 2008 09:56 PM
GU-50 output trafo croccodillo Tubes / Valves 7 11th May 2007 08:55 AM
Copyright 1999-2017 diyAudio
