Go Back   Home > Forums > > >
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 7th May 2012, 02:37 AM   #1
GanzerD is offline GanzerD  United States
Default A Newbie question....
I've been enjoying my SSE for the last 2 weeks.....
One thing I've noticed is that the input level seems to be going down gradually for my usual listening level.
Should I be worried about this? Is there a component that is degrading and changing the gain? Or is this normal?
TIA
Dave Ganzer
Old 7th May 2012, 05:57 PM   #2
rknize is offline rknize  United States
rknize's Avatar
Send a message via AIM to rknize Send a message via Yahoo to rknize
It wouldn't hurt to check the tube bias. You can also measure the voltage across the cathode resistors on the input tube to make sure it is operating at the correct current.
Old 7th May 2012, 06:08 PM   #3
At this point I wish I had written these voltages down when I checked them right after first power up....I'll look at those voltages again.
Being new to these tube things, I just wondered if this was normal to see during the initial few hours of operation.....
Thanks,
DaveG
Old 11th May 2012, 02:06 PM   #4
DigitalJunkie is offline DigitalJunkie  United States
Send a message via AIM to DigitalJunkie
A little bias drift and whatnot is fairly normal,for the first 'few' hours of an amplifiers operation,IME. After that,the various voltages,and bias,etc. should 'settle' a bit,and level out.
Sometimes tubes might have a bit of gas left in them,maybe the cathodes need to be heated up for a while,so the getters can warm up? Who knows,could be lots of things.
If things don't settle down,and you have wildly varying voltages/currents somewhere,I'd suspect bad tube(s),bad solder joint/connection,a faulty component,or oscillation.
Old 11th May 2012, 02:33 PM   #5
Thanks guys! I'll be checking it out Saturday morning...
L8R
DaveG
A Newbie question....Hide this!Advertise here!
Newbie with a question chevy2410 Chip Amps 36 14th March 2006 06:33 AM
newbie with input tran. question and wiring question imo Solid State 0 18th January 2006 10:10 PM
Newbie question rs1026 Multi-Way 7 12th November 2004 11:32 PM
newbie post, but hopefully not a newbie question wiredcur Solid State 3 24th August 2002 10:49 PM
Newbie Question, Christian Solid State 3 15th March 2002 06:55 PM
