diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Tubelab (http://www.diyaudio.com/forums/tubelab/)
-   -   Tubelab SE with tubes outboard (http://www.diyaudio.com/forums/tubelab/211999-tubelab-se-tubes-outboard.html)
crazyfrog 3rd May 2012 03:27 AM
I built the Tubelab SE with 45 triodes and a SS rectifier. All the tubes were installed on the chassis. Be careful if you do the same thing:
Install the stopper resistors close to the grid pin. 3.3k was enough for the 5842 and the I didn't change the 100R of the 45.
I had to add separate power supply and transformer for the 45 filaments to avoid noise (soft start using LT1084).
Since I had a little hum, more filtering was necessary (few hundreds microfarads) for the B+ supply. I had in mind to use stacked Zener diodes with a HV MOSFET for regulation and slow start: it works well.
Next step: the 211 stage!
Copyright 1999-2017 diyAudio
