Go Back   Home > Forums > > >
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 6th May 2012, 05:42 AM   #11
rknize is offline rknize  United States
rknize's Avatar
Send a message via AIM to rknize Send a message via Yahoo to rknize
Sound like the regulator is dropping out. I found that D5 and D6 are a bit overtaxed in this design when used for 300B duty. Swapping them for a pair of Schottky diodes props up the heater supply a bit and they run much cooler to boot.
Old 6th May 2012, 03:19 PM   #12
Green77 is offline Green77  Sweden
Hello.
D5 & D6? I don't have them in my schematic.. Is it the STPS30L30?
Old 6th May 2012, 05:15 PM   #13
Evenharmonics is offline Evenharmonics  United States
He meant D4 and D5. (Tubelab page)
Old 6th May 2012, 05:17 PM   #14
rknize's Avatar
Sorry, D4 and D5. The 1N5401s. When used with 45s, these just provide the bottom half of the bridge rectifier for the input tube filaments. When used with 300Bs, they become part of the bridge for the output tubes too. Mine run very hot...hot enough to discolor the PCB.
Old 6th May 2012, 06:40 PM   #15
Aha, thanks! I can try later this week to change them to 1N5821..I have them home. Will this raise the 6,3 V heater on input tubes?
//Daniel
Old 7th May 2012, 05:59 PM   #16
rknize's Avatar
It may raise it a tenth or two. You can check it afterwards and then adjust R3 accordingly.
Old 7th May 2012, 06:06 PM   #17
Ok, thanks. I will check it. Hope this stop the hum
//Daniel
Old 28th September 2012, 07:50 PM   #18
cotdt is offline cotdt  United States
Send a message via AIM to cotdt
What Schottky diodes are good to replace D4 and D5? I want to convert my TSE to a 300B eventually.
TSE question..Hide this!Advertise here!
TSE breadboarded, making music, LED question Alan Hope Tubelab 1 22nd January 2012 03:48 PM
TSE capacitor question cddeluca Tubelab 2 15th December 2011 02:34 PM
TSE Parts TerribleT Tubelab 12 14th October 2011 04:55 PM
TSE redone..working well..but :) Green77 Tubelab 6 29th June 2011 07:00 PM
TSE c4 question evanc Tubelab 4 20th April 2011 02:31 AM
