Go Back   Home > Forums > Commercial Sector > Vendor Forums > Tubelab
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 15th April 2012, 04:37 PM   #1
kkcinc is offline kkcinc  United States
Default SSE builder preferences
There are two places where Georges instructions call for whatever values you prefer. One is the volume pot. Why would I choose something other than 50k? The other is the coupling cap. Why would I choose something other than .22 uF?
Old 20th April 2012, 03:23 PM   #2
boywonder's Avatar
The R value of the volume pot (or an equivalent resistor if you are building a power amp config) is the load that your source will see, so a higher R is easier on the source (it doesn't have to provide as much current), but too high and it gets susceptible to external noise. Typical values are between 50K and 100K, although they can be as low as 25K or lower. If the value is too low, and your source can't provide the current, performance will suffer.
The coupling caps (in combination with the grid leak R) are an RC filter that determines the lower cutoff freq for the amp; this is typically quite low, like less than 10hz. Since the amp output will be -3db down at this freq, you want it to be lower than the audible range (20hz-). However, sometimes cheap/undersized output transformers will benefit from having a higher corner freq so that low freq energy does not saturate them. Changing the coupling cap value will raise or lower this frequency for a given grid leak R. Another example of needing a different coupling cap value is the case where one wants to bi-amp, ie use the amp to drive midranges only, or tweeters only. In that case, the coupling cap value can be chosen to have the lower cut-off freq at 100hz or 1000hz or whatever you choose.
Here is some related reading:
http://www.v-cap.com/coupling-capacitor-calculator.php
http://www.ampbooks.com/home/amplifi...ing-capacitor/
PCM1704 Preferences Ardee Digital Line Level 2 22nd July 2010 08:13 AM
Auricaps in SSE and SSE as a guitar amp. DanP Tubelab 5 12th July 2010 09:20 AM
FR preferences Salas Full Range 29 10th April 2005 01:34 PM
How lucky are we? TJ type 50 triode to be made. Make your preferences known now! jusbe Tubes / Valves 3 16th July 2004 05:18 PM
How to change email preferences? CZ Eddie Forum Problems 2 2nd November 2003 11:33 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
