Go Back   Home > Forums > > >
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 10th April 2012, 01:37 AM   #11
squiffiness is offline squiffiness  Canada
squiffiness's Avatar
Originally Posted by rmyauck View Post
...it will help the tubes last for years for a few cents as UF4007 diodes are at the most 35 cents each.
Is doing this in concert with a thermistor (GE CL90) in the 120VAC mains and a thermistor (GE CL140) on the HV secondary centre tap do anything for/against adding the UF4007 diodes to the HV secondary leads? I can't think of anything untoward they might do in concert. But, would having the thermistors heat and bring up voltage slowly hurt the diodes in any way?
Originally Posted by rknize View Post
Dropping C1 to 33uF would normally have a negligible effect on ripple. The relatively low DCR and inductance of your choke makes me suggest that you make up for it anyway with a bit more C in C2. It's probably not going to matter, but it's something to think about.
The C2 value doesn't have much impact on cost. The Caux value affects both sourcing where I live about 40 miles west of Toronto and cost. The 40 uF unit is readily available at a reasonable $20. Once I start calling HVAC contractors to but a motor run cap, the extortion starts along with upselling service on my furnace and central air. Sheesh.
Originally Posted by boywonder View Post
Squiffy, your choices look fine...and as Russ mentioned, the low DCR of your choke may result in a bit higher B+ than anticipated.
What I am seeing in PSUDII is an overshoot in B+ in the first few milliseconds up to about 500V, then undershooting from the final B+ of about 435V by a few volts, in my case (360-0-360 HV). Ripple is minimal.
You can always swap in a 5U4; that usually drops about +/- 30V than a 5AR4, depending on current draw. The 5U4 comes to life a lot faster than a 5AR4, so you lose some of the benefits of a soft start. Well, you still get a soft start but you'll get some B+ overshoot since the 5U4 will be conducting before the output tubes are warmed up.
Would the thermistors mentioned above have any impact on using a 5U4 and slowing its effects down a little?
I think I am more inclined to follow earlier advice and place some additional resistance in series with the choke to get the DCR closer to the 150R value of the design's R1 that is replaced by L1.
If the first cap value stays above about 10uf or so in a CLC PS, it won't change your final B+. Reducing the value of the first cap to less than 8-10uf or so will start to reduce your B+ voltage as the first cap value gets smaller. So you can always try some 1uf - 5uf or so caps for C1 to bring down your B+ if req'd.
Model your PS in PSUDII and play with the choke DCR and the value of the first cap for a quick and easy demo/sim.
The Amperex Datasheet I have for the 5AR4 shows the first cap should not be any lower than 4uF, which I tried. The B+ voltage did drop quite a bit. Little variation for C1 at 22, 30, 33, 47 and 56 uF.
I am trying not to stray too far afield from the suggested parts list, while trying to work in some budget limits for wife acceptance factor. I'd also considered Ty Bower's suggestion of switching to an LCLC ladder filter instead of the original Pi filter. Cutting a trace in the PCB is not in my plans right now.
I had also considered asking Edcor about the price impact of a custom winding on their XPWR002-120 power Tfmr by adding additional taps so I could get a 250-0-250 or 300-0-300 for other tube types like the older 6L6 family, for example. Then, swap the HV wires from the normal 360-0-360 to the lower ones and presto, lower resultant B+.
A guy can dream, can't he?
Appreciate the feedback from all.
Old 10th April 2012, 02:37 AM   #12
boywonder is offline boywonder  United States
boywonder's Avatar
The CL60/140 warm up pretty fast (like a second or two) at rated current, and will have little impact on the difference in warm up between a 5AR4 and a 5U4.
The Edcor NRE fee for a custom transformer is $40. Once someone orders one and pays the extra fee, it becomes stock product, like the XPWR-131 that Russ (Rknize) had made for the Tubelab SE so that we all can enjoy it. Thanks again Russ! It's a little shy on max secondary voltage for an SSE (330-260-0-260-330) though.
Old 10th April 2012, 02:45 AM   #13
rknize is offline rknize  United States
rknize's Avatar
Send a message via AIM to rknize Send a message via Yahoo to rknize
Would be good for 6V6, though!
Old 11th April 2012, 02:28 PM   #14
Tubelab_com is offline Tubelab_com  United States
Tubelab_com's Avatar
Not sure this would work with the printed circuit board mounted octal socket.
The diode trick does seem to help save 5AR4's especially some of the new "stuff". To do this on an SSE simply solder a diode on the end of each red transformer lead, put heat shrink over it and screw the free end of the diode into the terminal block.
No problem here. I have an SSE running with the diodes, and a CL-140. It works just fine. The diodes are being added to the next revision of the PC board. I must remove the old screened on name. The CL-140 might go in too, it depends if I can fit the parts without ripping too much up and changing things. That would require a whole bunch of new testing. Either way, it won't be ready for a month or two. You can put the CL-140 on the red/yellow transformer lead too.
A 33uF C1 cap is fine, and I too have seen the same issue with 47uF caps. I don't know what is going on with 500 volt caps, but the supply is sporadic and the prices are all over the place. Right now a 47 uF costs more than a 100 or 120 uF IF you can find them.
The 40 uF is good too. The purpose of the motor run cap is to provide a low ESR through the upper audio frequencies where some electrolytics start to behave like inductors. Their guts are wound up into coils of foil, paper and goo, so they ARE inductors. The electrolytic does the hard work, the motor run fills in the details. My TSE uses a 20 uF because that's all that fits in the chassis.
There are two possible places to install an inrush current limiter. Either, or both can be done in the same amp.
The usual place is in series with the transformer primary. I have done this. It serves to slow down the surge that comes when you flip the power switch, which can prevent switch arcs, and save tube heaters. It does little to help the rectifier tube since it warms up faster than the tube does. Use a CL-70, 80 or 90 here based on the size of the amp. An SSE gets a CL-90 since it tends to draw just over 1 amp.
You can put a CL-140 in series with the center tap of the HV secondary. It adds 50 ohms at turn on and drops to about 5 or 10 ohms after the rectifier tube is conducting. The CL-90 isn't good here since it needs a minimum of .5 amps. The current here is NOT even close to a sine wave and can't be measured with a meter. Even the CL-140 doesn't fully warm up, but it does help save rectifier tubes.
Tubelab, it's 5 year mission. To explore strange new tubes, to seek out new circuits and topologies, to boldly go where no tube has gone before......
Old 18th May 2012, 12:25 PM   #15
DimZ is offline DimZ  Greece
have anyone tried the 274A rectifier without changing the cap value ?
I have the stock value capacitor (47uf / 500V), the 193j hammond choke and a 80uf motor run cap ...
Old 30th May 2012, 08:25 PM   #16
Davec113 is offline Davec113  United States
Davec113's Avatar
This may be too late for the OP, but I just ordered a 47 uF 500V JJ brand cap from partsconnexion, it's about $6. I haven't heard much about them, but one member here said they are the best sounding electrolytics he's ever tried. They are designed for tube amp PS duties so I think they should be a good choice. Size is 22mm diameter x 42mm height, so it should fit on the PCB.
https://www.partsconnexion.com/capacitor_ele_jjcap.html
Old 30th May 2012, 08:35 PM   #17
Parts Connexion is about 30 minutes from my house and they let me do pick ups after completing my orders. Great to know this...hadn't considered them for passive components beyond sockets, pots and coupling caps.
~Squiff_________________________________
"Things are only impossible until they're not..."
Old 18th June 2012, 06:01 PM   #18
Davec113's Avatar
Got the JJ 47 uF 500V cap in and it fits the PCB just fine, it is 2x the size and 3x the weight of the original cap I was using... I also got 200 uF caps for my preamp project and they are also large and heavy for electrolytic caps.
Old 19th June 2012, 04:17 PM   #19
rknize's Avatar
I believe those caps are using older electrolytic designs, which is why they are bulkier. This is on purpose, as they are more for replacements in vintage equipment. In the C1 position it will work just fine. I have used them before in new amps without issue.
Old 8th December 2013, 02:45 PM   #20
pbkrag is offline pbkrag  United States
Which way do the diodes go?
SimpleSE: C1 valueHide this!Advertise here!
Kenwood C1 preamp schematic anyone ?? Jan Dupont Solid State 0 18th June 2007 04:29 PM
C1 for the ESP P68 leander Solid State 6 8th November 2005 07:14 AM
Aleph 5 - C1 too big? dantwomey Pass Labs 4 4th September 2003 05:53 PM
C1 and C2 in BoSoZ ruangrit Pass Labs 3 29th January 2003 04:06 PM
ZV4-Do i really need 50V for C1? till Pass Labs 2 16th September 2002 09:14 PM
