Go Back   Home > Forums > Commercial Sector > Vendor Forums > Tubelab
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 24th March 2012, 08:46 AM   #1
Default Simple Se transformer ordering check
Hi all,
I'm ordering my bits for a simple se build and I'm about to order the trannies from edcor but I wanted to check if I had them down correctly.
I've gone for the CXSE25-8-5k opt's
The XPWR059-120/240 (I'm in the UK)
And the CXC125-10h-200ma choke.
Sound good?
Thanking you!
Old 24th March 2012, 01:38 PM   #2
boywonder's Avatar
Looks like excellent choices. What output tubes are you planning on using?
The XPWR059 has a -50V bias tap that you won't need, but interestingly it's the same price as the XPWR010 which has the same specs without the bias tap. If you don't mind tying off the unused tap, the XPWR059 gives options for future projects. If you don't want to deal with a extra wire, consider the XPWR010.
If your plan is to crank KT88's at lots of bias current, you could consider a bit more current capacity than 175ma...although the ones above should work just fine.
Needing a 240V primary limits the Edcor choices a bit.....Their new sorting feature on the webpage is quite convenient.
Old 24th March 2012, 02:20 PM   #3
I haven't decided yet as to what tubes to use. I'm busy getting a variety of bits together ready for the build but wanted to get these on order asap due to the building and shipping times.
I'm curious about what combination tubes will work well with my speakers. I have some mk3 frugelhorns with Fostex fe126en drivers. They're a bit light on the lower end, not enough so that I'd want a sub of any sort but I'm unsure as to what can get the best of them on the lower end of the scale...
Old 29th March 2012, 04:58 PM   #4
boywonder's Avatar
As a sweeping generalization, KT-88's can provide good bass grunt, and EL-34's can do mids/vocals really well usually with a bit less bass, although amplifier damping factor and loudspeaker response will obviously play a large part.
Old 30th March 2012, 12:40 AM   #5
MellowTone's Avatar
I've tried KT88's (EHX), EL34's (JJ) and 6L6's (Russian 6P3S-e, Tung Sol)
KT88's give you more power, and good low end.
EL34's took me a while to warm to (pun not intended) but after a combination of burn in and getting used to them, pretty much found the same as boywonder (mids and vocals are excellent, if not a touch light on the bass)
Big fan of the Russian 6P3S-e, cheap as chips and they actually sound very good (have half a drawer full of these)
Recently (6 months ago) put the current production Tung Sol 6L6GC-STR in, and wow, they're brilliant. Built like tanks, sound beautiful through the whole spectrum and have almost as much bass as the KT88's I tried.
For preamp tubes, I've used almost solely old NOS or used tubes. Best out of those were the black plate RCA, Tung Sol and Cifte. Although 12AT7's are specified in the design, I've had some good results with a few of the other 12A*7 varieties. I've found a few of the current production tubes tend to be a bit harsh for my liking.
Rectifiers, I've been going for all NOS (or used but test well) tubes. They're not much more than current production and last a damn long time.
I Reject Your Reality And Substitute My Own
- Adam Savage, Mythbuster
Old 30th March 2012, 07:46 PM   #6
Thank you for the info guys. Its helped me pick my initial choice of tube. I've picked up some svetlana KT88's and some mullards for pre and rectifier tubes so hopefully I'll be off to a good start with them.
I'll try out those tung sol jobbies, they sound like a winner for sure!
Simple SE, Antek Transformer wushuliu Tubelab 6 11th February 2011 10:12 PM
input transformer for Simple SE Tubelab amp Salsero Tubes / Valves 7 10th October 2010 09:22 PM
Hot power transformer in Simple SE? fandersen Tubelab 4 23rd September 2010 02:51 AM
WTB - Simple SE Transformer Salsero Swap Meet 0 29th November 2009 05:26 PM
Tubelab Simple SE - Transformer Assistance ChrisR1983 Tubes / Valves 17 7th August 2009 07:08 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
