Simple SE 6l6 tube types - Page 4 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Tubelab
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 8th August 2012, 10:14 PM   #31
I've just learned about the Valve-art 350B's like few days ago. It's time I got new tubes for my amp. Looking at the Western Electric datasheet..it seems like we need some minor adjustments. Bias is only 50 mA and filament current draw is 1.6 Amp vs. just 0.9 for 6L6GC. I have 720 ohms resistor to keep bias happy but how to tweak the filament current draw? I'm using the Edcor XPWR0035. HV secondary has 2 amps available.
http://www.tubezone.net/pdf/we350b.pdf
Old 8th August 2012, 11:57 PM   #32
w5jag is online now w5jag  United States
You can't change the filament current draw of a tube.
You could add another filament transformer, I suppose - either as a stand alone or in parallel with your existing transformer to boost the current rating.
Win W5JAG
Old 9th August 2012, 12:48 AM   #33
vinylkid58's Avatar
Edcor XPWR035-120 has a 5A 6.3v CT winding. 5V winding is rated at 2 amps.
jeff
Old 9th August 2012, 01:08 AM   #34
kkcinc is offline kkcinc  United States
I can run the valve art 350b tubes all day long with 440v B+ and the 560 ohm resistors. In ul with feedback. They sound good and the plates don't glow. I don't think they are like the originals.
Old 10th August 2012, 12:51 AM   #35
How do your 350b tubes sound compared to your original 6L6WGT+?? I've got an se 6L6 amp that I really liked with the WGT+ Russian tubes and they can take 500V max and I thought they sound the best of all the vintage 6L6 I tried.
Bob
Old 10th August 2012, 03:53 AM   #36
Valve art supposedly sources from Shuguang. Shuguang 6L6G is only rated at 400V and 25 W plate dissipation. I guess Valve art 350B's have MUCH higher plate dissipation than that.
Old 10th August 2012, 05:47 AM   #37
Been busy digging for 350B datasheet. And found 350C datasheet. "C" stands for carbon so basically the same tube but with carbon plate. Plate voltage is 400V. So I guess using it with B+ of over 400V is not a good idea?
http://www.tubeampdoctor.com/images/File/350C.pdf
Also, since this tube draws 1.6 amps...is it going to be problem if The rectifier tap only has 2 amps? Kkcinc, Which transformer you are using?
Old 10th August 2012, 02:11 PM   #38
I really have no idea what the valve art 350b is. All i know is that it sounds quite good and did not blow up with 440v B+. Light and airy. Not a ton of bass, but very pleasent. I like it better than the 6l6wxt+, which is a very well regarded new production tube.
Old 10th August 2012, 06:25 PM   #39
Tubelab_com's Avatar
No, the output tubes run from the 6.3 volt winding which has nothing to do with the rectifier. As long as the total draw for all the tubes EXCEPT the rectifier (which has its own winding) add up to less that the rating of the 6.3 volt winding, you are OK in this regard.
The plate voltage is the voltage measured from the cathode of the tube to the plate of the tube. The B+ is the total voltage supplied by the amps power supply. Some of the B+ is lost in the OPT, and some is dropped in the cathode resistor. The usual loss in these two is 30 to 40 volts so you will be very close to the 400 volt rating. Most tubes have plenty of margin in this regard, but I have no experience with the 350B.
Tubelab, it's 5 year mission. To explore strange new tubes, to seek out new circuits and topologies, to boldly go where no tube has gone before......
Old 11th August 2012, 03:53 PM   #40
This means it's possible use NOS 807's rated for maximum of 400V plate voltage. Time to make some 5 pin to 8 pin sockets.
WTB: Silicone test lead wire for anode caps of 807's? I see Mouser has Pomona 100ft for 22$. But I want to know about other options.
6L6 SE Tube Amp Kit on eBay... opinions? bermtoog Tubes / Valves 12 19th February 2012 06:53 PM
Tube rolling input tubes Simple SE Anchan Tubelab 3 14th January 2011 07:05 PM
Simple SE Driver or Preamp Tube Structo Tubelab 0 22nd December 2010 06:35 PM
tubelab simple SE Tube selection help saletel Tubelab 10 19th December 2010 04:30 PM
Tube choices for Simple SE? BillEpstein Tubelab 16 18th May 2009 04:35 AM
Copyright 1999-2017 diyAudio
