Tubelab SE EL34 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Tubelab
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 14th March 2012, 06:31 PM   #1
Default Tubelab SE EL34
I'd like to try EL34s (triode mode) in my Tubelab SE. Did someone try those tubes in that amp? What would be the bias voltage in that case?
Old 15th March 2012, 11:55 PM   #2
nate is offline nate  United States
I'm a total nube, but EL 34s work great in a Tubelab Simple SE. The Tubelab SE used direct heated triodes like a 300b.
My Tubelab Simple SE is almost completed and I will be using EL 34s. All reports say that they sound excellent.
Best,
Nate
Old 16th March 2012, 04:46 PM   #3
rknize is offline rknize  United States
rknize's Avatar
Send a message via AIM to rknize Send a message via Yahoo to rknize
I tried it at one point. I know that George did a ton of experiments with triode-strapped octals on the TSE before he designed the SSE.
The bias current will depend on your B+ (are you running 45s or 300Bs). Use this as a guide (from the SSE manual):
Tubes & Transformers
Tubelab SE vs Simple SE Pez Tubelab 25 29th October 2011 03:16 AM
Need Help with Tubelab SE lth1 Tubelab 9 1st October 2010 10:06 PM
Tubelab Simple SE v.2 nic6paul Tubelab 3 1st November 2009 01:59 PM
tubelab se DimZ Tubelab 58 20th January 2009 01:47 PM
se 6c33c or se el34 schematic karma Tubes / Valves 10 2nd July 2005 06:40 PM
Copyright 1999-2017 diyAudio
