| Tubelab Discussion and support of Tubelab products, prototypes and experiments |
I've read a couple of older threads in this forum regarding socket extensions.
Will [shortly] begin building a SimpleSE. For heat management, it is clearly better to mount all the components on the silkscreened side of the board. However, doing so prevents mounting the board inside a conductive chassis. Anyone have any experience using any of: 1) Chassis mount 8/9 pin sockets and wiring the sockets to the PCB 2) Using some method of long pin PCB mount sockets (like Beltons) 3) Fabricating pin extensions like Tubelab shows on his Tubelab SE build site 4) Using NOS "socket savers". I have read that extending the socket could create some side issues related to tube performance (oscillations, THD effects, etc.) or unexpected consequences. Thoughts? Squiff |
#2 | |
If you are worried about heat, then provide adequate chassis ventilation. Think about serviceablility as well. You will most likely need to measure voltages across a few things when getting it up and running. |
#3 | |
I know I'd asked about mounting before in a previous thread. I am also interested in what sonic and electronic performance issues might arise by using either chassis mounted tube sockets and wiring them to the board for more clearance OR using some form of pin extensions to do the same. My hope is to hear also from a few of the testers in the audience and maybe Tubelab George himself about the pros/cons of elevated or hardwired sockets. Danke. |
| 8 pin dip extensions???? | rtate | Digital Line Level | 4 | 14th January 2009 12:44 PM |
| can new attachment extensions be approved? | jcx | Forum Problems | 1 | 17th August 2008 12:44 AM |
