| Tubelab Discussion and support of Tubelab products, prototypes and experiments |
Even tho' I've built a wonderful Simple SE my question reveals how little I know besides an ability to follow directions.
What would it take, if it were possible, to turn the Simple SE into a "headphone amp"? |
#2 |
Well, headphones often operate at higher impedance than speakers. My Grados are 32 ohms, if I remember correctly and others are in the 100+ ohm range. One thing you can do is to put a good quality resistor in series between the OPT and the headphone jack, which also helps to not over load the phones if a sudden click or pop happens (having burnt out said pair of Grados on an 8ohm unprotected tap, I can speak from experience). The other issues you may face is hum. Headphones being well, on your head, can really show hum up in a bad way. The amp has to be dead quiet for it to work well. Of course in all things, someone will likely contradict every point I've made, but hey, that's the way it goes. :-)
#3 |
headphone's drive requirements range over orders of magnitude - you really need to design for a given headphone's requirements
even keeping within "dynamic" - magnet and wire types Z can range from 16 to 600 Ohms, sensitivity from 83 dB/mW to 120 dB/mW 200 mV can drive sensitive iem ("in ear monitor") to over 120 dB, many of the portable "mp3 players" put out ~ 1 Vrms so lots of headphones Z, sensitivity are made for that drive "audiophile" and "pro" circumaural headphones often have lower sensitivity, higher Z and need more V and I headphone sensitivity traditionally was given in dB SPL re 1 mW drive power - some manufacturer's now use dB SPL @ 1 Vrms - you have to check amplifier output Z can affect some headphone's frequency response - there is a DIN? standard for 120 Ohms output but most headphones are now designed for very low output Z amps < 10 Ohms lots of info at the inactive but archived Headwize site HeadWize Library Last edited by jcx; 28th February 2012 at 08:46 PM. |
#4 |
There is nothing so practical as a really good theory - Ludwig Boltzmann When your only tool is a hammer, every problem looks like a nail - Abraham Maslow |
| Headphone amplifier | Tekko | Solid State | 7 | 27th June 2011 03:41 PM |
| help on headphone amplifier | theChris | Headphone Systems | 27 | 18th July 2010 05:36 AM |
| headphone amplifier | sparkle | Headphone Systems | 31 | 15th October 2007 11:33 AM |
| Headphone amplifier | audiofan | Headphone Systems | 5 | 3rd March 2006 03:43 PM |
| headphone amplifier?? | sunrise | Headphone Systems | 0 | 20th August 2005 11:17 AM |
