Go Back   Home > Forums > > >
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 17th February 2012, 02:39 PM   #1
Alan Hope is offline Alan Hope  Scotland
Alan Hope's Avatar
Default Rectifier tube change ... procedure?
TSE sounding extremely good, but some buzz from both speakers when B+ comes up - the buzz disappears completely after an hour or two playing. Filament noise?
About to try a new rectifier tube (JJ instead of Sovtek). I have ammeters wired in so I can watch the bias, however do I need to turn the trimmers down before installing the new rectifier?
And do I need to recheck my B+?
FLAC, Ethernet over Mains, SB3, GD Audio DAC 19. Tubelab SE with TJ Meshplate 45s. Fostex FE208ez in Kirishima Horns with Fountek NeoCD 2.0 Ribbon supertweeters (0.68uF & LPads).
Old 17th February 2012, 03:04 PM   #2
Osvaldo de Banfield is offline Osvaldo de Banfield  Argentina
Osvaldo de Banfield's Avatar
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
I think that electrolytic caps are old or bad. Try shunting with another of equal or bigger voltage and capacitance than original. Be careful with high voltages inside the set!!!
Osvaldo F. Zappacosta. Electronic Engineer UTN FRA from 2001.
Argentine Ham Radio LW1DSE since 1987.
Old 17th February 2012, 03:56 PM   #3
rknize is offline rknize  United States
rknize's Avatar
Send a message via AIM to rknize Send a message via Yahoo to rknize
How many hours do you have on the rectifier and the amp? If it is relatively new, you shouldn't need to make any major adjustments. It's worth verifying the bias anyway.
Old 17th February 2012, 04:10 PM   #4
Alan Hope's Avatar
@ Russ. Maybe 100 hours. I can see the bias continually anyway, so will just change the tube and watch carefully.
@ Osvaldo. This is a new build, and still breadboarded so yes I am being careful with the high voltages! I guess if the tube change makes no difference, I will have to start thinking about the caps, however I really need to get on with the casework - and lay out all the wiring/grounds properly before I declare the buzz due to a faulty component.
I blew the pretty little blue LEDs in the ammeters by my ignorance (didn't know they couldn't be wired in parallel and that LEDs don't obey ohm's law.) Noob, but learning.
Old 22nd February 2012, 11:55 PM   #5
cddeluca is offline cddeluca  United States
Alan:
My TSE also buzzes. I minimized it with a parallel motor run cap at C5. The buzzing I think is intrinsic at this point but noticeable to me because my 2-way speakers are BMS-4592 on a tractrix horns (~108 dB?) over JBL 2226's at (97 dB?). Altogether I attribute my situation to higher than usual speaker sensitivity which you might consider, too.
Old 23rd February 2012, 12:41 PM   #6
Alan Hope's Avatar
Thanks CD,
I have already installed a motor-run cap - no improvement. Speakers 96-97dB.
Curious thing is, the buzzing becomes inaudible after the amp has been on for about 1.5 hours. Turn it off for a while, and on again, and the buzz comes back.
Just to quantify this, it is audible at listening position, inaudible with almost all music, though just possible to hear during very quiet passages.
Rolled three rectifier tubes: no change.
The circuit is currently sprawled out on a breadboard, so I really need to case it properly before chasing this.
My previous SET initially had grounding issues causing hum, there were a few folk on the Decware forums chasing this, and finally one guy found the fix which was a supplementary large-gauge wire from the pot-ground to input-ground in parallel with the trace already present on the PCB.
Alan
Old 23rd February 2012, 01:57 PM   #7
PDL is offline PDL  United States
Could this be a mechanical buzz? I know if I get close enough to my SSE, I can here the power transformer buzz. If I then clamp the bells between my fingers it will go away.
Maybe after the transformer heats up from operating, the slight thermal expansion is enough to dampen the vibrations?
Just a thought
Old 23rd February 2012, 02:13 PM   #8
Alan Hope's Avatar
Definitely through the speakers, transformer is quiet.
It kicks in as B+ comes up.
I'm puzzled, because it seems a very long time to be a component warm-up phenomenon.
Old 23rd February 2012, 03:28 PM   #9
rknize's Avatar
Do you have a scope? How about cooling spray (or an upside-down can of dust spray)? It would be interesting if the temperature-related part has to do with the FETs or even the filament supply to the 45s. It has to be something solid state for the buzzing to go away over the course of an hour. I assume that both channels are affected the same?
Old 23rd February 2012, 05:37 PM   #10
Alan Hope's Avatar
Thanks for the input guys. I don't have a scope - but this is 50hz (UK mains).
I am probably trying to be too clever here with the warm-up stuff, the appearance of the buzz is consistent, but it doesn't always disappear (it is still there now after about 4 hours playing). My money is on mains interference from who knows where.
Both speakers are affected equally, and when it disappears both channels are clean.
I will ignore it for now and build the case, getting grounding properly sorted, then see where I am.
Will report back here ...
Alan
Rectifier tube change ... procedure?Hide this!Advertise here!
Tube change...what do you do? Skorpio Tubelab 6 2nd September 2011 06:53 AM
Which tube Rectifier is good enough for 5902 tube amp ? calico88 Tubes / Valves 14 30th July 2011 05:15 AM
converting tube rectifier to solid state rectifier. tubo Tubes / Valves 26 24th December 2009 12:12 AM
Anybody heard about Tarzian Silicon Rectifier for Tube Rectifier Replacement? zxx123 Tubes / Valves 4 21st February 2005 04:02 AM
Tube rectifier for VDIGC tube psu ebijma Chip Amps 2 11th March 2004 04:02 PM
