General Tubelab PCB question... - Page 2 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Tubelab
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 19th February 2014, 05:30 PM   #11
evanc is offline evanc  United States
Location: New Jersey. About 1 hour from NYC and 1 min. from the beach
mines been working like this for some time. The small silver heatsink[Q1 Q2 U2 U3] gets hot...
http://www.evancotler.com
Old 19th February 2014, 06:47 PM   #12
boywonder's Avatar
Default keeping the smoke in.....
Moggi: When populating the bottom of the PCB, triple check the polarity of anything that has polarity, like diodes, electrolytic caps, mosfets, and the tricky one, the filament regulator (5 legged critter).
Old 19th February 2014, 06:50 PM   #13
moggi1964's Avatar
I saw that you mentioned that on your build, boywonder; the 5 legged beast being the most challenging it seems.
Thanks for the advice; I need to get my head around what the implications are of working on the other side of the board.
TEAC RH 500 Amplifier Vista Phono1+ w/ TEAC TN-400. Loth-X Ion 1 BS & Emotiva XDA2. WIP: Tubelab SE 300b
Old 19th February 2014, 07:08 PM   #14
wicked1 is offline wicked1  United States
wicked1's Avatar
I soldered the 5 terminal regulator to its pads, laying flat off the back of the board.
So, all the pins are fully extended, not bent, not cut, And the ends are soldered to the pads. Then the regulator extends past the pcb where I have it mounted to a heat sink.
(which is why on the photo of mine a page back, the vent holes by the regulator area extend way out past where the PCB is)
Old 19th February 2014, 10:33 PM   #15
moggi1964's Avatar
Thank you.
Old 21st February 2014, 01:37 AM   #16
moggi1964's Avatar
I think I am going to put the taller caps under and have everything else on top.
C5; 6, 8 and 10 for example can go under, maybe others too.
This should give me shorter standoffs and thereby the tubes will be more above board than below.
Old 21st February 2014, 01:03 PM   #17
Spica is offline Spica  Canada
EVANC
That is one very beautiful enclosure!!
I wish my woodworking skills were at your level.
Old 21st February 2014, 01:09 PM   #18
moggi1964's Avatar
So when I put it on the bottom the negative terminal is soldered to the same 'hole' it would have been on top, right?
Old 21st February 2014, 02:26 PM   #19
boywonder's Avatar
The leads of all of the devices listed above would go into the same PCB holes as they would if top mounted. The filament regulator is the only brain-twister, as it has 5 leads.
Old 21st February 2014, 04:31 PM   #20
moggi1964's Avatar
Yeah, I think I am going to keep that one on top
Thanks mate.
Using the HYPNOTIZE as a general shunt reg PCB Salas Power Supplies 649 4th April 2016 06:57 PM
Tubelab SE - Sockets off PCB? dagerman Tubelab 14 27th July 2011 05:16 PM
FS: tubelab simple SE pcb spgjmf Swap Meet 1 3rd March 2010 07:53 PM
General Puropse small chip amplifier (sch + pcb) Elektor78 Chip Amps 4 30th December 2008 05:48 PM
General Amp Question RobPhill33 Solid State 8 21st January 2003 03:34 PM
Copyright 1999-2017 diyAudio
