Go Back   Home > Forums > > >
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 21st January 2012, 09:59 PM   #1
Alan Hope is offline Alan Hope  Scotland
Alan Hope's Avatar
Default TSE breadboarded, making music, LED question
The 100mA meters have blue LED backlights, and I believe (no documentation) they need 6-12v AC or DC (DC preferred to avoid flicker). Quick question, what is the best way to achieve this?
1) Simply wire a cheap transformer in parallel with the main transformer?
2) I have a spare 50V tap on the transformer - any way to reduce this to 12V and use that?
3) The green output wires on the transformer are the 6.3v / 6A input used to drive the regulator which generates the F+. Can I tap this for the blue LEDs?
FLAC, Ethernet over Mains, SB3, GD Audio DAC 19. Tubelab SE with TJ Meshplate 45s. Fostex FE208ez in Kirishima Horns with Fountek NeoCD 2.0 Ribbon supertweeters (0.68uF & LPads).
Old 22nd January 2012, 04:48 PM   #2
Alan Hope's Avatar
From Bottlehead forums ...
An LED plus 1000ohm resistor in series from 6.3v tube heaters will draw about 20mA, and should cause no problem.
Will try this.
TSE breadboarded, making music, LED questionHide this!Advertise here!
TSE capacitor question cddeluca Tubelab 2 15th December 2011 03:34 PM
TSE c4 question evanc Tubelab 4 20th April 2011 03:31 AM
First OTL breadboarded Brit01 Tubes / Valves 23 16th October 2010 08:52 PM
how? --> making a flashing led multiplexor Parts 31 19th January 2003 01:33 PM
Making LED voltmeter Dima Equipment & Tools 5 3rd August 2002 02:11 PM
