Go Back   Home > Forums > Commercial Sector > Vendor Forums > Tubelab
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 4th February 2013, 05:41 PM   #21
Davec113's Avatar
Originally Posted by rknize View Post
Given that the resistor is bypassed by a huge cap, I am a bit skeptical that the cathode resistor design can make an audible difference here unless something else was awry.
Not only does it make a difference, it is a rather large night-and-day type difference.
Old 5th February 2013, 01:22 AM   #22
rknize is online now rknize  United States
All the best stuff comes from Chian
rknize's Avatar
Send a message via AIM to rknize Send a message via Yahoo to rknize
I wasn't trying to say that your ears have been fooled. I'm just wondering if there is something else at play here, such as some unwelcome inductance or something not ideal with the bypass caps.
Old 14th February 2013, 01:58 AM   #23
It's a small price to pay given the quality you are getting for the price of their OPTs. I was so pumped when I found out about these guys from this forum, especially how they can so easily make custom power transformer designs and are willing do to so for the DIYer. No more scrolling back and forth through Hammond's website trying to find a workable solution only to have it overheat and be way out of spec in the end.
For the switch, it doesn't have to be double-deck. It just needs to have two poles. For 6 or fewer positions, they can fit two poles on one deck. Just FYI if you are searching on Mouser or wherever. Mine is 2P6T single deck:
If I get this picture correctly all the resistors are connected a common wire
that goes to the ground connection of R17 and R27 then the the wires from
the two center pins one each go to the live connection of R17 and R27 is
this correct ?
The additional wires connected to the center pins and the two outer pins
where do they go ?
Old 14th February 2013, 02:14 AM   #24
rknize's Avatar
There are 4 other resistors that are not pictured here. They are 680 ohm, 5W types in the big, rectangular package (same Yageo SQP series that George specs in the parts list). They are mounted in a piece of aluminum u-channel that acts as a heat sink to the chassis. There are two used for each channel. One is permanently connected to the PCB in the R17/27 position. The other is in parallel, with one of the leads connecting here. So with the switch rotated in the fully CW position, I have two 680 ohm power resistors in parallel, for 340 ohms.
Old 14th February 2013, 03:51 AM   #25
Is this why you connected them separately from the other resistors ?
Do they generate a lot of heat when paralleled for 340 ohms ?
Old 14th February 2013, 06:37 PM   #26
rknize's Avatar
They dissipate about 2W each. It was mainly a space issue. It would have been rather tight right there between the shield plate and the PCB.
SimpleSE + Preamp skipper Tubelab 4 13th December 2011 03:24 PM
Need Some SimpleSE Help gasser-dude Tubelab 30 29th December 2009 12:12 AM
new SimpleSE build nvrgdenuf Tubes / Valves 0 23rd February 2009 03:14 AM
6V6GT in the SimpleSE w5jag Tubes / Valves 10 2nd May 2008 02:44 AM
SimpleSE and me allyourzigg Tubes / Valves 8 1st August 2007 02:44 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
