Go Back   Home > Forums > Commercial Sector > Vendor Forums > Tubelab
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 3rd January 2012, 12:29 AM   #1
jrenkin is offline jrenkin  United States
Default mosfet failure
How would one know if they had a mosfet fail?
Old 3rd January 2012, 12:36 AM   #2
nigelwright7557's Avatar
Quite often they go short circuit from drain to source.
Check it with a multimeter on the ohms setting.
I have seen a gate to source short as well but only once.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software.
Old 3rd January 2012, 06:15 PM   #3
thank you
Old 6th January 2012, 06:19 PM   #4
I measure 17K ohms across the d-s for a disconnected never used 2sk3563, the same as my used ones, when disconnected. Does that seem right?
Old 6th January 2012, 06:39 PM   #5
rknize is online now rknize  United States
rknize's Avatar
Send a message via AIM to rknize Send a message via Yahoo to rknize
Google for it. There are a few simple techniques to test the gates.
mosfet driver failure lorenzo_cy Power Supplies 4 4th July 2008 07:39 AM
Tube Failure jwatts Tubes / Valves 11 12th February 2005 06:54 AM
Organ Failure jackinnj Instruments and Amps 4 1st January 2005 03:09 PM
7591EH failure Frank Berry Tubes / Valves 10 30th August 2004 05:18 AM
Tube failure Christopher Tubes / Valves 47 30th May 2003 03:35 AM
Page generated in 0.07324 seconds (71.70% PHP - 28.30% MySQL) with 10 queries
