| Tubelab Discussion and support of Tubelab products, prototypes and experiments |
I must have done something to fry them both, sigh.
First checkout was fine, then I hooked up an input signal, no sound and then re-check showed a mess. I am not sure what wires I crossed where, But something happened. It is a point to point sett up, so that may be more prone to happen. The current situation with the driver circuit is no matter how I adjust the 5842 bias resistors, I can only get 87-95 volts at the plate, measured directly. I can adjust the bias resistors from 0 to 500 ohms and that works fine. The CCS grid and current set resistors are fine and to spec per the schematic.Ground is correct and I have tried 4 tubes. I have full B+ at the center pin of the IC, and voltages similar to the plate voltage on the other pins. There do not seem to be any shorts or anything, so I can only guess it is a problem with both ICs. Really? Any other thoughts? Go figure, I bought multiple extras of every component in the parts list EXCEPT the CCS ICs, sigh. On an additional thought, if I want to try to get it running with a traditional bias circuit and no Mosfet, just to make sure I can get the other parts to work, all I need to do is replace the grid leak with a larger resistor, maybe 50K or any suggestions? |
#2 |
Sorry. mixed up my plans with mosfet and
CCS. I could replace the CCS witha 23-25K resistor, right? |
#3 |
How would you wire up a 23-25k resistor? I have a problem buying CCS's so if one can replace it with a resistor that would be great.
#4 |
Well, I think it would end up being more around a 10K resistor, if my math is correct. It would simply replace the CCS and associated resistors. A standard resistor load for the stage. You might have to try few to get the current right, it is an interplay between the cathode resistance and the plate load resistance. A CCS is theoretically better, but I am not sure since I seem to be unable to get mine to work. The circuit is fine, so I must have fried them, I did get way too much voltage for a while. I hope I haven't fried the Mosfets too, or any caps...
I am about to order 10 IXCP10M45S CCS IC from digikey, I won't need that many, should I drop two in an envelope and hope they make it to South Africa undetected? |
#5 |
Thanks but I think I'll be okay for now, problem is not customs it's Ixys who doesn't allow digikey and mouser to ship outside their areas because we have a local importer(that doesn't stock the CCS's) I found an online shop that ships here, just expensive, but I'll know for sure what the situation is like when I plug in the new tubes.
| 45 TSE Checkout Fail | Alan Hope | Tubelab | 13 | 17th January 2012 08:42 PM |
| TSE Parts | TerribleT | Tubelab | 12 | 14th October 2011 04:55 PM |
| fail of a rail in a regulated PS | ErikdeBest | Chip Amps | 15 | 7th March 2006 07:39 AM |
| speaker protection - fail again - help please | bigpanda | Solid State | 29 | 18th August 2005 03:32 AM |
| CCS Conceptual Qs, Using Gary Pimm CCS as Example | DrDeville | Tubes / Valves | 20 | 12th May 2004 02:41 PM |
| Page generated in 0.07306 seconds (78.62% PHP - 21.38% MySQL) with 10 queries |
