| Tubelab Discussion and support of Tubelab products, prototypes and experiments |
I've been trying to find some further information about the biasing and MOSFET implementation of the TSE and have struck out. Can anyone point me to some discussion or clarify the design basis? Is the bias arrangement to limit current at 150V? The particular values are arbitrary? And with the MOSFET between the bias network and the grid, does that mean that you're essentially biasing the drive voltage from the 5842 rather than pulling the output tube grid down? Very confused.
Also the MOSFET source resistor (bias resistor?); how is that determined? The 'Power Drive Cookbook' has quite a discussion of SE Amp CAD but it doesn't address how to translate the results into the MOSFET implementation. Any info is greatly appreciated! Thank you. Charlie Last edited by cddeluca; 21st December 2011 at 09:31 AM. |
#2 |
I think i found two answers on a guitar amp forum
-setting the bias on the gate leg of the mosfet is the same as biasing the tube grid directly minus 3-4 volts since that is the (fixed?) difference between the gate and source of the mosfet -the bias resistor arrangement seems to be based on negligible power dissipation as to not 'steal' amps from the circuit; micro-amp currents Has anyone any hints about the mosfet biasing question? THANKS! |
#3 |
I found most of the rest of the answer here:
Understanding the Tubelab SE It discusses biasing the mosfet to "a reasonable" current within it's linear region. What's linear? Looking at the datasheet for the 2SK3565 Vds is constant for Vgs greater than 8V, which is easily satisfied in the TSE. Rds appears constant for Id < 1A. Since the grid current will be very small in any case, biasing the FET somewhere between 0.01 and 1A would be sufficient, at the expense of dissipation. So it seems that 50mA of bias might be good. With Vdd about 400V and Vb at around -150 then a 20K resistor would bias the mosfet at ~30mA, so I guess that's how it's done. I would still appreciate anybody's take on this if you're so moved. Thanks! Last edited by cddeluca; 22nd December 2011 at 11:52 AM. |
#4 | |
#5 | |
Here is a related thread Mosfets for Tubelab SE? |
#6 |
I appreciate the link - the Crss thing seems to be minimized for Vds >100 in the 2SK3565 that I've bought. Can't find anything to relate it to bias current, though.
| TSE Bias Trimmers and Check Points | jeffx | Tubelab | 5 | 11th November 2011 10:28 PM |
| 2A3 TSE blown Fuse and MOSFET | btran | Tubelab | 5 | 14th November 2010 06:54 PM |
| How to bias mosfet in Class-A | Anchan | Solid State | 18 | 7th August 2010 10:39 AM |
| MOSFET bias current | pengpeng | Solid State | 8 | 5th February 2009 11:30 AM |
| bias circuit for mosfet help | AudioGeek | Solid State | 2 | 29th April 2006 11:22 PM |
| Page generated in 0.08947 seconds (76.12% PHP - 23.88% MySQL) with 10 queries |
