diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Tubelab (http://www.diyaudio.com/forums/tubelab/)
-   -   TSE capacitor question (http://www.diyaudio.com/forums/tubelab/202529-tse-capacitor-question.html)
cddeluca 15th December 2011 12:35 AM
Can't seem to find a mention on the forum - C6 in the schematic is 100uF, 350V; in the parts list it's 47uF, 450V.
Seems that 100uF/350V is correct, but can anyone verify this?
THANKS!
cddeluca 15th December 2011 11:09 AM
Clarification
C6 is the filter input capacitor to the bias supply filter...
Tubelab_com 15th December 2011 02:34 PM
When the schematic was drawn 350 volts was enough since most amps used 45's 2A3's or 300B's at 350 volts or less.
Now we have 300B's and super 300B's, and even hot rodded 2A3's that will run at 400 volts or more. If you are building an amp that runs the B+ below 350 volts then use the 350 volt cap. If you are going to run a higher B+ then C6 must be rated for the higher voltage. Use the largest capacitance value that will fit the PC board at your chosen B+ voltage.
Resources saved on this page: MySQL 18.75%
