| Tubelab Discussion and support of Tubelab products, prototypes and experiments |
I'm contemplating using a separate power supply for the mosfet drains in my 45 version of the Tubelab SE. I'm using 2SK3563 mosfets. I have a 230V CT secondary Hammond flat pack transformers (P/N 229B230). It'll do 115V at 100ma or 230V at 50ma.
Is rectifying and smoothing 115V sufficient for a 45 build? Or, put another way, how much drain voltage do I need for the 2SK3563's? The sources are connected to the bias circuit per the schemo. I'm using the Edcor XPWR-131 power transformer and the rest of the build is per George's parts list. I'm assuming that I just leave out the jumper between the B+ and DRV B+ pads, and connect the aux power supply to the DRV B+ pad....... |
| TubeLab SE - power supply | cypher | Tubelab | 2 | 29th July 2011 05:42 PM |
| Separate Power Supply Case | nwboater | Class D | 5 | 27th June 2011 11:59 PM |
| Tubelab SE build and power supply questions. | Binaural | Tubes / Valves | 54 | 3rd March 2010 03:20 AM |
| Switchable stages with Tubelab’s hybrid MOSFET/ 845 SE amp? | rick57 | Tubes / Valves | 0 | 5th September 2006 07:56 AM |
| separate chassis power supply | onixuser | Class D | 2 | 4th March 2005 08:42 PM |
| Page generated in 0.05755 seconds (70.15% PHP - 29.85% MySQL) with 10 queries |
