| Tubelab Discussion and support of Tubelab products, prototypes and experiments |
#11 |
Both my SP-P and SSE have been operating for hundreds of hours now on their original (cheapo) Chinese 5AR4's. No sparks; no arcs. (Sound of knocking on wood!) I'm thinking the currently available tubes are probably all over the map for quality /reliability, so it's luck of the draw.
"We provide the music, you provide the silence." - Charles Mingus |
#12 |
A tube that has manufacturing defects bad enough that it is going to spark out, will usually do so the very first time you turn it on. If they have lived this long, they should be OK.
As the emission dies off with age the possibility of a sparking death increases. Again an uneven cathode coating or improper alignment will cause uneven cathode wear.
Too much power is almost enough! Turn it up till it explodes - then back up just a little. |
#13 | |
I have to say that it's been a very long time since I have seen any that bad. The situation where the cathode has been unevenly coated is another real quality problem. You may also see the cathode oxide material flaking off or maybe even rolling around in the tube. Pitch those in the bin. If the quality of the tube is that poor, I would expect all kinds of problems. Low vacuum and solder failure in the base pins are other signs of shoddy workmanship. Even the appearance of the internal elements may not be parallel with others too. Never use stuff like that. I'm agreeing with George that your rectifier tube was / is very probably a good one. Arcing and other forms of discharging within a good tube can wreck it in no time. There is a possibility that your tube was damaged. Do you have another piece of equipment you can plug this tube into to test it? I have seen more than my fill of badly designed power supplies in equipment with low secondary winding impedance and silly large filter caps. Using a high capacitance filter that is above the maximum rating in the tube manual is just plain wrong. This doesn't even buy you anything in the way of performance. -Chris
"Just because you can, doesn't mean you should" © my Wife |
| WTT: Various tubes for 6CA4/EZ81 rectifier tubes | GordonW | Swap Meet | 4 | 27th August 2008 12:37 AM |
| Rectifier Tubes | denny9167 | Tubes / Valves | 10 | 21st April 2008 06:12 PM |
| Tubes Rectifier Help? | papanohn | Tubes / Valves | 3 | 23rd July 2007 05:05 AM |
| Sparking Tubes! | jaymanaa | Tubes / Valves | 4 | 16th January 2006 10:00 PM |
| Rectifier tubes | yuval | Tubes / Valves | 8 | 14th June 2003 06:40 AM |
| Page generated in 0.08223 seconds (77.94% PHP - 22.06% MySQL) with 10 queries |
