Go Back   Home > Forums > > >
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 2nd December 2011, 02:14 AM   #11
Tubelab_com is offline Tubelab_com  United States
Tubelab_com's Avatar
I was curious why George doesn't, in the interest of safety.
I didn't use insulators in my amps because there are lost of dangerous things on that board and I believe that they should all be off limits to the user once the amp is completed.
I assume that no crazy designer has used the heatsink as a current / signal path.
Crazy designer....yes, but.....There are no electrical connections through the heat sinks, so an insulator can be added if the parts are well heat sunk. Many builders have pushed the board to voltages that I never thought of when I designed it. The "standard conditions" for a 300B 7 years ago was 360 to 375 volts at 60 to 80 mA. The Russian and Chinese tubes that I use will blow up at 400+ volts.
Higher voltages increase the dissipation in the mosfets and a insulating pad will increase the thermal resistance. If you have installed larger heat sinks and want to use an insulator, then go for it. If you built the board as designed and are running over 400 volts, it might not bee too good of an idea.
Tubelab, it's 5 year mission. To explore strange new tubes, to seek out new circuits and topologies, to boldly go where no tube has gone before......
Old 2nd December 2011, 02:36 AM   #12
lanchile is offline lanchile  United States
lanchile's Avatar
one time I got a big shot when I was checking a Sony ES serie receiver, I touched the heat sink and I did not see that my other hand was touching the chassis. The heat sink got really hot when it was at normal volume and when I increased the volume to 1 o'clock..uffff I could cook an egg on it!!!. I sold it to my friend and He also noticed and He told why I sold him a heater lol.
high voltage on heat sinkHide this!Advertise here!
High voltage and heat sinks pof@ Tubes / Valves 24 28th September 2010 07:33 AM
Is this heat sink OK? portreathbeach Chip Amps 5 28th February 2010 11:56 AM
voltage reg make heat sink live. Bad idea? phrarod Tubes / Valves 4 10th December 2008 12:57 AM
Required heat sink troystg Chip Amps 9 15th November 2004 01:40 AM
How much heat sink is necessary? rosss Pass Labs 11 23rd February 2003 05:23 AM
Copyright ©1999-2017 diyAudio
