Go Back   Home > Forums > Commercial Sector > Vendor Forums > Tubelab
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 17th January 2012, 02:28 AM   #11
beeah is offline beeah  United States
Originally Posted by Alan Hope View Post
Some background hum - hopefully casework, motor-run cap, will reduce that significantly.
Glad to hear you got it working.
I too just got a TSE 45 up and running, and I was disappointed to hear so much background hum, despite that fact that it made beautiful music. I replaced R4 with a 8H choke, and the hum has disappeared. YMMV, but I'd give that a shot before doing anything else.
Old 17th January 2012, 05:45 PM   #12
Alan Hope's Avatar
THanks ... but I had a choke installed from the start. Adding the motor-run cap has made no difference. The whole thing is a breadboard tangle of wires at present - plenty of scope for hum. Anyway I will do the casework now, get the earths properly sorted, then see where I stand.
The music is sublime though! This will be worth it.
FLAC, Ethernet over Mains, SB3, GD Audio DAC 19, Tubelab SE 45, FE206eN in Scotmoose Sachikos with Fostex FT17h supertweeters 0.68uF cap.
Old 17th January 2012, 06:58 PM   #13
jrobson is offline jrobson  South Africa
Well done, how far are your OPT's from your input transformer and choke?
Old 17th January 2012, 08:42 PM   #14
Alan Hope's Avatar
Transformer is at 90° to OPTs, they are in a line, fairly close - just as they are in many commercial / diy SET amps. Choke fairly close by, not much option on the breadboard. Inputs are twisted. Still got a multi-meter attached to B+.
I'm not going to systematically chase hum until these are all mounted on a sheet of aluminium with the power components on the left, OPTs on the rear, input paths well away from power components, and earthing properly done. I remember spending ages going through all this with my previous amp - it was a revision to the grounding which solved it there.
I won't be able to start casework until next week. Got the aluminium sheet and a set of drill-bits for the various holes required. Same basic construction as my previous amp, so I'm on familiar ground.
Previous amp:
External:
Internal:
Will post progress here ...
Alan
45 TSE desired tube current? Acceptable B+? Alan Hope Tubelab 8 5th December 2011 12:07 PM
45 Central Aluminium 45 Adapters mainscablesrus Mains Cables R Us 0 2nd November 2011 09:26 AM
TSE Parts TerribleT Tubelab 12 14th October 2011 04:55 PM
SimpleSE Checkout/CL-90 Fail wushuliu Tubelab 13 9th March 2011 03:49 AM
Tube designs: 45 driving 45/2a3/300b? Veniogenesis Tubes / Valves 4 23rd April 2007 06:59 PM
Page generated in 0.07884 seconds (74.48% PHP - 25.52% MySQL) with 10 queries
