Go Back   Home > Forums > > >
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 28th November 2011, 06:47 PM   #1
Alan Hope is offline Alan Hope  Scotland
Alan Hope's Avatar
Question 45 TSE desired tube current? Acceptable B+?
Reached the checkout stage, and must confess a bit nervous. Read and re-read the checkout/bias sections of the manual, a couple of questions ...
Near the end I do the "slowly adjust pots R12 R23 to raise output tube current to desired."
What is the desired output tube current for 45s?
What is the acceptable range for B+ in a 45 TSE?
FLAC, Ethernet over Mains, SB3, GD Audio DAC 19. Tubelab SE with TJ Meshplate 45s. Fostex FE208ez in Kirishima Horns with Fountek NeoCD 2.0 Ribbon supertweeters (0.68uF & LPads).
Old 28th November 2011, 07:08 PM   #2
evanc is offline evanc  United States
Location: New Jersey. About 1 hour from NYC and 1 min. from the beach
The 45 should be biased in the 25 to 30 mA range. I use 28 to 30 mA on 280 volts, and 26 or 27mA if operated at 320 volts.
right out of the manual.....
http://www.evancotler.com
Old 28th November 2011, 07:49 PM   #3
Alan Hope's Avatar
Ta,
Yeah, found it now. Blush.
One more question. I have breadboarded the amp at present. I have Electraprint OPTs - do I need to ground the outputs from these?
Old 2nd December 2011, 12:32 AM   #4
boywonder is offline boywonder  United States
boywonder's Avatar
Grounding the speaker negative assures nothing is floating, and at my house, I sometimes run vintage Polk SDA speakers (with an umbilical between them) that requires the speaker -ve to be grounded.
I'm no expert, but IIRC it's also important to ground the speaker -ve when running gnfb (not the case here, of course)......
Old 2nd December 2011, 07:24 AM   #5
JP is offline JP  United States
JP's Avatar
There's also a safety issue in that if the primary shorts to the case or the secondary, you'll have full B+ on the case or secondary. Speaker negative and the transformer case (at one of the mounts) should always be connected to earth.
Old 2nd December 2011, 07:47 AM   #6
Nikon1975 is offline Nikon1975  Austria
Not in all the OPT. Silk transformers are designed to have the secondary floating. The case should be grounded.
D.
Old 2nd December 2011, 10:27 AM   #7
Alan Hope's Avatar
Thanks ...
The Electraprint transformer legend says of the negative output - "this to ground if needed"
Will start with negative ungrounded, case grounded.
Old 5th December 2011, 12:45 PM   #8
jrobson is offline jrobson  South Africa
You should ground the grey wire, there is a thread on here where George states that you should ground them.
Old 5th December 2011, 01:07 PM   #9
Alan Hope's Avatar
OK, will do.
45 TSE desired tube current? Acceptable B+?Hide this!Advertise here!
Bad TSE Input Tube? jeffx Tubelab 10 29th October 2011 03:55 AM
Tube PS question: Acceptable ripple Guiseppe Power Supplies 15 14th November 2010 11:42 AM
Acceptable Acceptable Load for Lite 60 DAC 6922 Output Tubes dtm1962 Digital Source 0 14th November 2010 02:03 AM
Acceptable Ripple Current for Aleph 2 hifileslie Pass Labs 3 9th August 2009 11:35 PM
Tube designs: 45 driving 45/2a3/300b? Veniogenesis Tubes / Valves 4 23rd April 2007 07:59 PM
Copyright ©1999-2017 diyAudio
