diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Tubelab (http://www.diyaudio.com/forums/tubelab/)
-   -   Allied Transformer Runs quite Hot (http://www.diyaudio.com/forums/tubelab/200538-allied-transformer-runs-quite-hot.html)
kkcinc 15th November 2011 02:35 AM
Finished Tubelab simple se and it sounds great. Using kt88's, transcendar 3k opt's, 4ohm tap, 560 cathode resistor, negative feedback, tube rectifier and ultralinear. B+ is exactly 440vdc. Allied 6K7VG seems to run hot. Not hot like the tubes, but hotter than the transformer on my 60wpc factory pp kt88 amp. Is this normal? Did I make a mistake going cheap on the PT?
TonyTecson 15th November 2011 03:58 AM
do the 5 second test, if you can hold on to the traffo with your bare hands for 5 seconds without feeling burned, then it is probably not an issue....
kkcinc 15th November 2011 12:05 PM
I don't think it is hot enough to burn me, but I'll try it.
Tubelab_com 15th November 2011 12:51 PM
The Allied is made by Hammond and like all Hammonds it runs hot. In your set up the transformer will be unconfortably warm. I have been running mine with 470 ohm cathode resistors and KT88's (not recommended). It gets too hot to touch after an hour of use, but it is still kicking after 5 years. So are the original tubes.
The Hammond 200 series gets about as hot as the Allied. The 300's run a bit cooler (not much) but cost more.
kkcinc 15th November 2011 01:40 PM
Thanks, that is good to know. I just measured the surface temp after about an hour. 123F/51C degrees. Not as hot as I thought.
PreSapian 17th November 2011 10:36 PM
what are some cooler running trafo brands that can be used for tubelab SE?
Copyright 1999-2017 diyAudio
