Go Back   Home > Forums > > >
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 13th March 2012, 06:41 AM   #81
jrobson is offline jrobson  South Africa
Yeah, the first batch I was able to measure the pins and noticed the tube was shorted, by then the board was a bit "worn out" from messing around a lot trying to find the problem, second batch it all seemed fine on the pins but when I put it together it blew a mosfet instantly, it could be that I broke them installing, I don't like the design overall because it appears to be quite frail, then went with my known working but not as suitable 900v mosfets and the CCS's blew, then decided to get new tubes again, new CCS's still on the 900v mosfets and worked no problem. I'll look into going to the recommended mosfets again later, I also need to get some better trim pots, the ones I have make it very tricky to set the bias, not sure if it's normal?
Certainly thanks to you that I got it working again, was quite interesting, ever seen a 5842 at 450v? It's like a beautiful red flashlight
Try 6C45Pi if you don't mind messing with the 5842 pinout, it's the same tube with different pins afaik, I think still made too. There is a guy on here who modified the design significantly and you can use his schematic and go with 6SN7's which is still made as well.
Old 13th March 2012, 06:49 AM   #82
Oh, haha it sounds good, but it has a lot of hum now that it's assembled so I'll play around see if I can get it out.
Old 13th March 2012, 01:52 PM   #83
Will there be any problems with 2A filament 300B tubes? I have U1 and D1 on a very large heatsink.
Old 16th March 2012, 10:53 PM   #84
rknize is offline rknize  United States
rknize's Avatar
Send a message via AIM to rknize Send a message via Yahoo to rknize
Should be fine. The regulator IC has thermal protection and will shut down if it overheats.
Old 24th March 2012, 11:06 PM   #85
After about 10 - 15 hours or so this happened to me:Tubelab Simple SE - fuse blowing
One diode measures 99/94(depending which way around) and gets there quickly when I set it on the diode test, the other one gives a 821 one way and nothing the other...
I don't know if the tube sparked, I didn't see, music just went dead, saw the fuse was blown then decided that before I replace it to neaten up the wiring, so I powered it up with a new fuse and no tubes, kept on blowing fuses, R5 got quite hot at one stage so I thought must be the FRED diodes.
Solution new diodes and a new rectifier tube or is there something else to look into?
Old 25th March 2012, 12:00 AM   #86
Another problem, figured I'll do the checkout again since I put new wires in, problem is with the output filament supply, 8.9v instead of 5...
I am using this: http://www.vishay.com/docs/94328/94328.pdf and this http://www.sharpsme.com/webfm_send/611
Measuring Pin1:8.9v, Pin2:8.9v, Pin3:ground, Pin4:2.27v, Pin5:8.9v
Any ideas?
Old 25th March 2012, 12:53 AM   #87
How about this?
https://secure.cedist.com/scripts/fo...P?item=T-SSR01
But I don't want a stand-by switch, is there an automated delay solution?
Old 25th March 2012, 01:37 AM   #88
Any ideas?
Ignore this stupid post, I suppose if I isolated the components when I mounted them on the large heatsink I wouldn't have seen this problem.
Old 25th March 2012, 01:37 AM   #89
How about this?
Found a soft start, bought a solid state rectifier and the soft start... Will report back if it all works ok.
Build coming together nicelyHide this!Advertise here!
Dolby AC3 coming on nicely. Doz Tubes / Valves 13 21st September 2011 06:41 AM
Coming soon to a thread near you... Cal Weldon Multi-Way 57 20th May 2011 01:03 AM
Delta3 coming along ... David Gatti Multi-Way 18 11th July 2007 07:06 AM
Copyright ©1999-2017 diyAudio
