Go Back   Home > Forums > > >
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 22nd January 2012, 02:40 PM   #61
jrobson is offline jrobson  South Africa
Yeah I can, I'll do that now, I've also found some 12xK resistors, quite large probably around 3w each, in parallel I'm measuring 43K
Old 22nd January 2012, 02:48 PM   #62
Okay, with OPT's off, B+ cut from Mosfets, same as before, 0.
Old 22nd January 2012, 03:04 PM   #63
Okay with the resistors I'm at 80v...
Old 22nd January 2012, 03:06 PM   #64
Make that 146v when the coupling cap is connected.
Old 22nd January 2012, 03:31 PM   #65
jrenkin is offline jrenkin  United States
Maybe try more in parallel if you have them.
I haven't run the sim yet, everyone woke up.
You probably want a little higher plate voltage, and set the cathode voltage around 3v, recheck the plate and calculate current through the tube. If you can get 160--180ish plate voltage and a current 7--13mA you should be able to trust your tubes and try it in the whole circuit.
You may have already have proved the ccs bad.
Old 22nd January 2012, 03:47 PM   #66
Looks like around 31K-32K, I get 172v without the output tube in.
There is a difference between left and right though, I reconnected the coupling cap and still only getting 85v or so on one side.
Can you pm me your price and paypal info and I'll take your board and 2 CCS's, I'll just rebuild with a new pcb and see if I have better luck second time around.
Old 22nd January 2012, 04:54 PM   #67
There can be big differences between tubes, if you can't get one of them right by adjusting the bias resistor circuit, it may need a different load, a problem with 5842 tubes that George solved with a ccs and variable cathode bias.
I don't need to make any money on the parts. Maybe $30 plus shipping total? How best to ship to you? I can send them and then give you a total, not today though.
Old 22nd January 2012, 04:57 PM   #68
Well I figured I'll use this board to find the problems and fix on the new one, sent you a pm.
I'll play around a little more and swap some parts from left to right see where it all goes.
Old 22nd January 2012, 05:08 PM   #69
Alexontherocks is offline Alexontherocks  Italy
honestly I haven't read the whole thread but if it helps I'll share this bit of information:
Sometimes throughholes in pcb get damaged or are damaged from production. I experienced lack of gain from my pmillet red board and it turned out everything was correct (values, types of components ecc) but because of desoldering and soldering some connections were missing or damaged.
Difficult to explain but maybe this is what the issue is. I solved my problems by soldering a new board and adjusting soldering temp to less than 300C if soldering small leads.
Hope it helps, good luck
Old 22nd January 2012, 05:16 PM   #70
Thanks Alex...
It is quite possible, there is certainly a lot of damage
Build coming together nicelyHide this!Advertise here!
Dolby AC3 coming on nicely. Doz Tubes / Valves 13 21st September 2011 06:41 AM
Coming soon to a thread near you... Cal Weldon Multi-Way 57 20th May 2011 01:03 AM
Delta3 coming along ... David Gatti Multi-Way 18 11th July 2007 07:06 AM
Copyright ©1999-2017 diyAudio
