| Tubelab Discussion and support of Tubelab products, prototypes and experiments |
I need a rectifier switch to go from ss to tube in a simple se. Can anyone post a link to a good switch? I have an on off switch from a local electronics store. It is rated at 277vac and 20amps but no dc rating listed. What do you guys use? Also how about the triode ul switch and nfb switch?
#2 | |
One would hope that you will not use that switch with your mains switch being in the on position, so all the switch does is connecting the cathodes of the diodes to one of the pads for the filament of the (then not present) rectifier tube. I haven't used any rectifier switching option on my SSE amps, because I like the soft-start effect of the rectifier tube warm-up and I have enough B+. I have used regular DPDT switches like these for CFB/UL, just because I had them. You can probably get away with ones rated for less than 6A... Again, the max current rating of your OPT primary/secondary windings is probably a good start for those switches.
There are 10 types of people: Those who understand binary and those who don't. Last edited by dagerman; 2nd November 2011 at 10:43 PM. |
| Tubelab SE vs Simple SE | Pez | Tubelab | 25 | 29th October 2011 02:16 AM |
| Simple SE Simple Power Drive? | Skorpio | Tubelab | 1 | 5th May 2011 09:45 AM |
| EMG active pickups - simple on-off and on-off-on switches? | oatmeal769 | Instruments and Amps | 2 | 16th November 2009 04:52 PM |
| Simple Dc-dc Converter | redhorseaudio | Car Audio | 0 | 6th December 2008 04:17 AM |
| A simple way to create dual(or more!) rotary switches out of single rotary switches | stappvargen | Pass Labs | 14 | 16th April 2004 11:33 PM |
| Page generated in 0.06596 seconds (68.96% PHP - 31.04% MySQL) with 10 queries |
