Go Back   Home > Forums > Commercial Sector > Vendor Forums > Tubelab
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 14th October 2011, 01:24 AM   #1
kkcinc is offline kkcinc  United States
Default Simple SE more OPT questions/ideas
"Cathode feedback is used in this diagram. The secondary of the OPT's are connected to ground on the PC board so a separate connection is not needed. Note the reverse connection of the output transformer secondaries. This is needed on many OPT's to get NEGATIVE feedback to the cathode of the output tube. If unsure of your particular OPT's try wiring the secondaries each way (swap the two secondary wires, leave the primary alone). Chose the connection that produces the lowest volume."
I think Gery at Transcendar is going to build me some custom 20w opt's with 40% ul tap. Question is-does anyone know if the transcendars need reverse connection of the opt's secondaries for UL. I know I can try it both ways, but it would be nice to get it right out of the gate.
Simple se ideas gazzgary Tubelab 5 9th September 2011 01:56 AM
Tubelab simple SE ideas gazzgary Tubes / Valves 2 7th September 2011 04:18 PM
Simple Simple SE questions nodiak Tubelab 57 2nd February 2010 11:02 PM
Tubelab Simple SE OPT Query (Hammond 1628SE vs 1629SE) Junior Tubelab 13 25th December 2009 11:30 PM
Mikael Abdellah SE KT88 ideas and questions kacernator Tubes / Valves 6 14th January 2008 01:09 PM
Page generated in 0.05903 seconds (68.45% PHP - 31.55% MySQL) with 10 queries
