Go Back   Home > Forums > > >
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 16th October 2011, 04:14 PM   #31
Herr Grau is offline Herr Grau  Germany
Herr Grau's Avatar
Send a message via ICQ to Herr Grau
I too would strongly recommend O/Netics. Bud makes absolutly awesome OPTs. I would always go through the trouble of importing from the USA again.
Old 16th October 2011, 04:28 PM   #32
smbrown is offline smbrown  United States
smbrown's Avatar
How about the Lundahl line? I've not heard them, I know Allen Wright used the PP ones in his commercial amps. The 1663 is $150, it is a C core transformer. It is also availabe in Amorphous Core for 2x. I have not heard it, be nice to hear some reports.
Old 16th October 2011, 04:52 PM   #33
DualTriode is offline DualTriode  United States
Originally Posted by tubelab.com View Post
I did not answer this post at first since I assumed that it was all about transformers that were all beyond my budget. Now that the thread has ventured into familiar territory I can say that I tend to use "budget" OPT's but I have a set of custom Electra Print 5K:8 "10 watt" OPT's in my Tubelab SE. I run that amp wih 45's or 300B's and it is the best sounding amp I have built. It has been auditioned along side some rather expensive amps with favorable results. I got the Electra Prints so long ago that they were $100 each.
I have another Tubelab SE running triode wired 307A's that uses the large Edcors. It sounds nice, but is not as detailed as the Electra Print amp with 45's in it.
Tubelab and All,
I have read your counsel regarding the Electra-Print 5K:8R counsel in several locations now.
I followed the Electra-Print 5K:8R recommendation and purchased the same and have only glowing recommendations.
Not the most expensive, but definitely high end.
DT
help me choose a high end opt for tubelabs SE!Hide this!Advertise here!
Tubelabs Simple SE board tigrine Swap Meet 0 25th September 2011 09:13 PM
Lineup of four: Help me choose?! OPT for SE WE91 Tubes / Valves 87 2nd February 2011 01:12 AM
Tubelabs Simple SE board + parts albireo13 Swap Meet 6 19th March 2010 11:59 AM
Tubelabs SE vs. Simple SE ?? albireo13 Tubelab 16 21st February 2010 10:00 PM
Looking to "Borrow" an Amplitrex, 539C or other High-End Tube Tester in SE PA Area baileyler Swap Meet 0 14th January 2009 03:07 PM
