Go Back   Home > Forums > > >
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 11th July 2012, 01:47 AM   #41
boywonder is offline boywonder  United States
boywonder's Avatar
Originally Posted by victorm View Post
Thanks very much for this! This seals my decision to go with the Big Edcors ;-) which should hopefully go well with the XPWR131-240 and CXC125-10H-200mA.
Just on the other topic - does anyone have any volume pot recommendations? I was thinking about Potentiometer - 100K Dual, Linear PC Mount, 3/8" Bushing | Antique Electronic Supply LLC...
Any feedback is greatly appreciated.
-Victor
Victor, the power transformer and choke look fine. The XPWR-131 allows both 300B's and 45's/2A3's to be used. It was specifically spec'd for the TSE.
You really want an audio (not linear) taper pot, although the other pot specs look fine.
Old 11th July 2012, 04:38 AM   #42
victorm is offline victorm  Australia
Thanks Boywonder,
Yes I do now realise a LOG pot should be used ;-) However, I was more concerned about the pot value ;-) Have since found this thread:
Simple SE volume pot value???
where George is saying that for TSE the pot should not be higher than 50K due to low pass filter it would create with the Miller cap of the 5842. Just trying to understand how low can I go? All I could get at the moment is 10K pot.
All this is a theoretical discussion for now as the lead time for Edcors is 5-6 weekes plus whatever it takes to ship to Australia...
Thanks a lot for your help,
-Victor
Old 12th July 2012, 09:50 AM   #43
Hey guys, has anyone purchased the 5842s from AES?
5842/417A - Triode | Antique Electronic Supply LLC
Are they OK? Any other reputable sources? Thanks in advance,
-Victor
Old 22nd August 2012, 05:08 PM   #44
zman01 is offline zman01  Bangladesh
Help with Tubelab SE component selection
Default Rust on laminations...
I got a pair of One Electron UBT-2 transformers - a bit disappointed to see some rust on the laminations...
Any reason for concern?
Help with Tubelab SE component selectionHide this!Advertise here!
tubelab simple SE Tube selection help captainpabst Tubelab 10 19th December 2010 04:30 PM
Basic chipamp component selection bcdzt5 Chip Amps 32 12th January 2008 01:05 AM
Component selection for best performance (LM3886). CJ900RR Chip Amps 0 24th February 2006 02:10 PM
Component selection eitanwaks Tubes / Valves 31 4th February 2006 06:27 AM
Need help on speaker design, and component selection BrianGT Multi-Way 5 5th February 2002 03:39 PM
