| Tubelab Discussion and support of Tubelab products, prototypes and experiments |
Good day folks out there,
I am completing my Tubelab SE with 300B and I am having a weird problem. Without the power tubes (300B), I can read 5volts for both filaments. When I insert tubes, everything works for one or two minutes and then filament power shot down. I turn off the amp for a few minutes (until B+ and B- go down to 0volt), then I power up again and everything works for one and two minutes and shot down again, etc. etc. B+ and B- remain OK (B+ = 415V and B- = 295V). When I don`t put any power tube, filament voltage stays on forever, well I less 15 minutes. I tried 50ma on tubes, same result with a lot of distortion. With 60ma, distortion seems to be gone but I have no scope to validate. Any suggestions where to look at? Alain Last edited by Bola; 13th September 2011 at 12:09 AM. Reason: Typo |
#2 |
Location: New Jersey. About 1 hour from NYC and 1 min. from the beach
maybe the filament regulator is overheating.
try blowing a fan at it and see if it stays powered up longer....
http://www.evancotler.com |
#3 |
Yup....pretty common problem with the stock heat sink in the 300B configuration (the instructions mention this). The amp was originally designed for 45s.
#4 |
It sounds like the voltage regulator for the 5 V filament supply is going into thermal shutdown. Try with a larger heat sink.
~Tom |
#5 |
It seems to be a concensus. I also read the same from a different blog. I am going to try to cold it down with a fan.
I confirm I only have the stock heatsink - no add on. |
#6 |
Here's another thing to try: Pull one of the 300B's and operate the amp as a mono amplifier for a while. It should take longer for the regulator to reach thermal shutdown then.
The idle/quiescent current of the 300B has no impact on when the regulator goes into shutdown. ~Tom |
#7 |
You are all correct. With a fan on the IC, everything is back to normal.
I will add a better heatsick like George is recommending. Thanks everybody for the quick help! Alain Last edited by Bola; 13th September 2011 at 12:56 AM. Reason: Typo |
#8 | |
That amp lost a power transformer in its first year, but autopsy revealed water damage due to hurricane forced water intrusion because I left the amp near a windowduring the storm. Yes, the window was closed. The replacement transformer has been in the amp for 6 years. It gets too hot, but doesn't blow up.
Too much power is almost enough! Turn it up till it explodes - then back up just a little. |
#9 | |
As a note, my board was not mounted in a chassis yet. I conclude that the IC is probably not well mounted on the heatsink. Anyway, I have larger heatsink that I plan to install this week end. Thanks for the advice. Alain |
#10 |
My TSE is also just sitting on a bread board. With 45s, convection was enough to keep it working (but it was still very hot). With 300Bs, I got 10 or 15 minutes of playing before it gave out. I clamped an aluminum "squangle" to the heatsink to get it to stay happy until I re-did the bread board.
| Any issues with adding a grounded power cord to a Heathkit IT-17 tube tester? | BoilermakerFan | Tubes / Valves | 2 | 27th June 2010 07:34 PM |
| Weird old power transformers (filament, SS and tube) - $7 each! | pjanda1 | Swap Meet | 6 | 29th March 2010 04:17 PM |
| Standard tube filament voltages and currents | ilimzn | Tubes / Valves | 5 | 4th January 2010 05:53 AM |
| Tubelab SE input tube filament | Evenharmonics | Tubes / Valves | 3 | 25th January 2009 12:10 AM |
| Tube-amp power issues | Klimon | Tubes / Valves | 8 | 18th December 2006 08:29 PM |
| Page generated in 0.10394 seconds (81.77% PHP - 18.23% MySQL) with 10 queries |
