Go Back   Home > Forums > Commercial Sector > Vendor Forums > Tubelab
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 12th September 2011, 03:28 AM   #1
hartze11's Avatar
Default Damping Factor
Hi all,
Just curious if anyone has measured the DF of their Tubelab amp...
I measured my Tubelab SSE at a value of 4, into an 8-ohm resitive load (at 80 Hz). This amp has the big Edcors currently installed. I tried a range of mid-volume levels, and typically saw about 0.75 V drop between loaded and unloaded.
I used this formula: DF = E_no_load/( E_no_load - E_loaded), e.g.
3V / ( 3V - 2.25V ) = 4
Just curious if this seems right or common...
Thanks,
Dave
Old 12th September 2011, 06:20 AM   #2
rknize is online now rknize  United States
rknize's Avatar
Send a message via AIM to rknize Send a message via Yahoo to rknize
Sounds reasonable. What tubes, what B+, and what primary impedance on the OPT?
Old 12th September 2011, 03:52 PM   #3
hartze11's Avatar
The B+ is around 430 V, with EH EL34s. Also using the recommended 5 kOhm impedance. Rk = 560 Ohm.
Dave
Old 12th September 2011, 04:20 PM   #4
kevinkr's Avatar
Actually quite typical (and good) for designs where there is no global feedback in use. (There is the option for local cathode feedback in the output stage)
www.kta-hifi.net
Old 12th September 2011, 04:49 PM   #5
rknize's Avatar
A little over 4 is about right for this amp with your setup.
Old 12th September 2011, 10:25 PM   #6
Ty_Bower's Avatar
Originally Posted by hartze11 View Post
I used this formula... E_no_load vs. E_loaded...
Hmm. As a general rule, I try to avoid running my vacuum tube amplifiers with no load. Mostly you are OK, but sometimes you fry an expensive output transformer. Just my two cents.
Old 13th September 2011, 05:05 PM   #7
hartze11's Avatar
I try to avoid it as well, but this was a quick test, on relatively low power.
Everything is still working fine, but I would recommend to anyone to keep the test short.
Old 13th September 2011, 11:35 PM   #8
tubelab.com's Avatar
I try to avoid running my vacuum tube amplifiers with no load......I would recommend to anyone to keep the test short.
Time duration shouldn't matter. The "rule" comes from the fact that current through an inductor can NOT be instantly switched off. An unloaded OPT is essentially an inductor. At low signal levels the amp will behave normally without a load. As soon as you hit clipping the output tube will attempt to cutoff. This switches off the current flow through the OPT and the voltage will tend toward infinity. Stray capacitance and inductance will limit the rise time thereby limiting the absolute voltage rise, but often the voltage will rise to a point high enough to start an arc somewhere. The arc is then fed by the B+ and something will fry even if signal is removed.
I have seen it happen, and even provoked it to see what happens. The likely places for an arc to start is inside the OPT (fries it), inside the base of the output tube (may or may not be fatal), from pin 3 (plate) to pin 2 (heater) of the output tube socket (sometimes blows the power transformer since multiple KV is on the heater winding, but I have seen it blow a 12AX7 in a guitar amp).
Too much power is almost enough! Turn it up till it explodes - then back up just a little.
Old 2nd October 2011, 04:40 PM   #9
boywonder's Avatar
Default a couple of questions.......
Is there another appropriate method of measuring DF without having to unload the output transformer?
For the above test, do you input a sine wave and measure AC volts at the output both with and without a load?
Old 2nd October 2011, 08:14 PM   #10
hartze11's Avatar
Yes, input a sine wave... this article recommends 50 Hz:
Damping Factor with Calculator
But I noticed that my amp started to roll-off below 60-70, so I used 80 Hz.
Measure the voltage drop between loaded (I used a non-reactive 8 Ohm resistor) and unloaded.
Not sure I would do this again, unless I want new transformers...
Dave
p.s. Nice to meet you at BA 2001.
Damping Factor in Amplifier brianti Solid State 37 14th September 2004 12:16 PM
Aleph4 damping factor alanyeoh Pass Labs 1 17th August 2004 09:11 PM
Damping factor Cro maniac Chip Amps 29 8th May 2004 01:16 PM
Damping factor thylantyr Solid State 9 14th March 2003 06:37 AM
Damping factor..????? emarald Solid State 15 30th January 2003 02:41 PM
Page generated in 0.12013 seconds (81.64% PHP - 18.36% MySQL) with 10 queries
