Damping Factor - Page 2 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Tubelab
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 3rd October 2011, 01:37 AM   #11
Tubelab_com's Avatar
Is there another appropriate method of measuring DF without having to unload the output transformer?
Yes, you can measure the output voltage with any two different load resistors and use a formula. I am 1200 miles away from my lab so I don't have the formula handy now. I use two identical 8 ohm resistors so I can get 4, 8 and 16 ohms. Scope or measure the output to verify that the amp doesn't go into clipping ,or the numbers won't be accurate.
Tubelab, it's 5 year mission. To explore strange new tubes, to seek out new circuits and topologies, to boldly go where no tube has gone before......
Old 3rd October 2011, 02:04 AM   #12
jan.didden's Avatar
I don't have the equation on the top of my head either, but you can do as follows.
You measure the Vout with two different values of load, and calculate the output current for the two situations. Then you take the difference between the two load currents as delta-I, and the difference between the two Vout's as delta-V. Rout = delta-V/delta-I.
jan didden
Music is dither to the brain; lets me think below the usual chaos - me
Linear Audio Vol 13 is out! Check out my Autoranger and SilentSwitcher
Old 3rd October 2011, 02:13 PM   #13
boywonder's Avatar
Thanks guys! I was assuming that two different loads would work; same as above except both R values are finite.......
OK next question......if using 2, 4, 8, 16 ohm loads, connect them all to the 8 ohm tap? (I have 4 and 8 ohm taps available).
Damping factor Cro maniac Chip Amps 43 4th August 2015 02:09 PM
Damping Factor in Amplifier brianti Solid State 37 14th September 2004 12:16 PM
Aleph4 damping factor alanyeoh Pass Labs 1 17th August 2004 09:11 PM
Damping factor thylantyr Solid State 9 14th March 2003 06:37 AM
Damping factor..????? emarald Solid State 15 30th January 2003 02:41 PM
Copyright 1999-2017 diyAudio
