SSE/KT-88/Transcendar OPT: UL? CFB? Why? SSE/KT-88/Transcendar OPT: UL? CFB? Why? - diyAudio
Go Back   Home > Forums > > >
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 9th September 2011, 07:44 PM   #1
dagerman is offline dagerman  United States
dagerman's Avatar
Default SSE/KT-88/Transcendar OPT: UL? CFB? Why?
Hey there,
I just finished my second TSSE build (after the 300B TSE needed to be shelved for now due to some issues I can't fix given my current knowledge level...).
I used:
- Hammond 274BX PT
- 193J choke and ASC motor run cap
- 5AR4
- EH 12AT7 and KT-88
- 5k Transcendar OPTs
- 470Ohm for R17/R27 (cathode res.)
- Auricaps coupling caps
It sounded great out the gate without UL or CFB. As others have noted, amazing low and mid frequency sound (it actually has quite a punch and I am testing with cheap-ish Polk Audio floor standers), but definitely less detail than the first EL34-based I built.
I just hooked up the UL tap and don't hear much of a difference.
Has someone by any chance built a TSSE with similar iron and tubes and experimented with the UL and CFB options? It's easy enough to try, but I am wondering what I can expect with either of these options, and/or with both of them combined.
I also have a pair of UBT-3 OPTs lying around, but they don't seem to be a good match given 450V of B+. George may try them just to see how much smoke they make....
I am not really looking for things that show up only on an FFT Spectrum Analyzer, but mostly for audible improvements. I listen to all different kinds of stuff depending on mood. It could be Charlie Hunter one day and AC/DC the next.
Anyway, I'd be curious to see what other folks' experiments with UL/CFB have resulted in (pointers to other similar discussions I have overlooked are perfectly OK).
Happy Friday,
Stefan
There are 10 types of people: Those who understand binary and those who don't.
Old 10th September 2011, 01:27 PM   #2
Ty_Bower is offline Ty_Bower  United States
Ty_Bower's Avatar
Originally Posted by dagerman View Post
- Hammond 274BX PT
- KT-88
That sounds like my amp. I used the 374BX, and 510 ohm cathode resistors, but otherwise the same. If you search a bit, you'll probably find my thread. Over time and with repeated experimentation, I've chosen to run my Simple with no feedback and triode mode. My Transcendar outputs are slightly older versions, and the UL tap is at 50%. I think he now builds them with the tap at 40%.
http://s69.photobucket.com/albums/i4...E/P1100484.jpg
Old 10th September 2011, 04:17 PM   #3
dagerman's Avatar
Thanks Ty. I had picked a 510 Ohm resistor from the table as well, but they are still on backorder at Mouser, so I used 470 for now...
I'll experiment some and see if I can tell any difference in sound with the various options, but may stick with basic triode mode myself, since it already sounds pretty fantastic.
And yes, the newer Transcendars have a 40% UL tap.
Have a good weekend!
Stefan
SSE/KT-88/Transcendar OPT: UL? CFB? Why?Hide this!Advertise here!
Another KT-88 cryo Tubes / Valves 23 1st October 2008 03:06 PM
KT-88 from a book diesel_tech Tubes / Valves 20 25th February 2008 01:07 AM
6p3s vs kt 88 hbi Swap Meet 6 28th November 2007 05:25 AM
Need PP KT-88 amp design and KT-88 for triode use? Norris Wilson Tubes / Valves 7 23rd February 2005 12:12 PM
Copyright 1999-2017 diyAudio
