Go Back   Home > Forums > > >
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 11th October 2011, 02:32 AM   #11
beeah is offline beeah  United States
Originally Posted by TerribleT View Post
2. FDPF5N50NZ-ND Beeah said he would use this part. Beeah, how did it work out?
Sorry, can't help you there. I managed to find the original 2SK3563 MOSFETs from a vendor through Amazon - hopefully they're genuine... Can't test yet as I'm still waiting on my Edcor order.
Old 14th October 2011, 04:49 PM   #12
boywonder is offline boywonder  United States
boywonder's Avatar
Default about those MOSFETs....
I'm curious about the required voltage rating of the MOSFETs......in the TubelabSE it appears that the source-drain voltage can be high, especially when running 300B's at 375-400V or so, since the -ve rail can be upwards (downwards?) of -300V for a difference of 700V or so. It would seem like the 500V rated parts wouldn't stand much of a chance. Are the 2SK3563's and other 500V rated parts only appropriate when running 45's?
Is it as simple as looking at the source-to-drain voltage difference? I suppose the 20K/36K R connected to the source side has something to do with it......do those R's drop all of the voltage?
Old 14th October 2011, 04:55 PM   #13
diecast is offline diecast  United Kingdom
Default I have been gathering parts for so long that...
I got my TSE board on May 2007 and at the time the 2SK2700 was still available here and there and I got some. I also have some 2SK3563 I acquired more recently - the result of "well maybe..." type thought process that means I also have five different sets of coupling caps. I expect there are fellow sufferers out there.
So which is preferable? From the Crss graphs I have it looks like the 2SK2700 may have a lower capacitance but more variable with voltage whereas the 2SK3563 has about 7pF but dead flat.
I do get round to making things BTW. I will post some pictures of my SSE later.
Andrew
TSE PartsHide this!Advertise here!
TSE redone..working well..but :) Green77 Tubelab 6 29th June 2011 07:00 PM
Running a TSE with 5u4g? discomonkey Tubelab 6 30th April 2011 03:30 PM
TSE c4 question evanc Tubelab 4 20th April 2011 02:31 AM
Motor Run vs. Solen in TSE jeffx Tubelab 8 5th March 2011 07:00 PM
Lost a channel in my TSE oldmanStrat Tubelab 4 26th August 2009 12:13 AM
Copyright ©1999-2017 diyAudio
